Hey guys.
I'm hearing a strange sound that i at first thought was spark knock due to a poor tune or even rod knock or worse, but I'm leaning towards a bad lifter due to the high consistency/repeatablity of the sound (and not to mention I've added a ton of fuel and killed timing to make sure). These are the details of the sound:
-Sounds like a rapping similar to spark knock
-Only occurs under medium/high load acceleration AND
-Only occurs above 3k rpm OR around atmospheric on the boost gauge
-Does not occur under very light acceleration up to redline
-Does not occur when revving in neutral
-Does not seem to be heard at engine RPM
-Just started occuring within the last 50 km on a new RB25/30 build
I had to spin the cams around several times when the engine was dry to put the timing belt on. Is it possible there's air in the lifters now? Is there anything I can try before i proceed to pull the damn thing apart? Any other ideas?
Thanks.
https://www.sau.com.au/forums/topic/334855-rb2530-bad-lifter/
definately has a bearing type knock not a pinging sound and is wierd how it only does it under load,
how rich is it when it ramps up and makes the sound?
my 2 cents is bearing knock but in early stages and needs load to be evident
drain your oil into a clean container and sit it in the sun. you will be able to see if there is any bearing material in it. if so, $60 worth of oil and $80 worth of new bigends is cheaper than a new bottom end....
better to be safe than sory.
To test if its big ends, warm the motor up till its capable of making the sound when free revving, then disconnect 1 coilpack at a time until it doesnt make the sound anymore...
If one of the coilpacks being undone cuts the sound, you know youve got rod knock.
I am all for trying to slap in a new set of bearings too provided the crank isnt marked. Had one chew RIGHT OUT on me before and luckily didnt mark the crank. Motor is still going today :)
Thanks guys I'll try the thing with the oil.
The thing is it doesnt make that sound when free revving with no load. Thats the strange part. And it really doesn't seem like its at engine RPM which is why I'm thinking valvetrain... FML.
Edited by ST240
I understand that... But shouldnt you be able to hear rod knock just free revving the thing?
It definately isnt spark knock. Just logged a run, AFRs in the low 10s, timing was 10* (!) map was anywhere from vac to 4 psi. And it still makes the sound as loud and as consistent as ever. Please tell me that isnt spark knock, although i wish it was.
Edit:
Here it is free revving. No knock sound.
Edited by ST240
Well there was shiny particulates in the oil/filter. Quite a bit and smaller than grains of salt. The oil also had a silvery swirl to it. For comparisons sake i changed the oil in my dd 240sx beater with at least 2k+ km since last change and there wasnt nearly as much. Under half the amount. So for the RB to have double the f**king particulates on 200 km doesnt look good at all.
Is there any point in pursuing further? Are particles typical on a rebuild? I was going to try driving it while disconnecting one injector/coilpack at a time to see if i could isolate it. But i definately do not want to wreck the crank. FML. Serious.
Edited by ST240
Its not hard to remove the sump and take a look. If its a big end bearing you'll find a heap of copper particles sitting in the sump. You'll also be able to push on the rods to see which one has any signs of movement/wear.... as long as the crank is still ok you should be just looking at some new big end bearings...
yeah id remove the sump, take the caps off the rods and check them out, see if its more than 1 failing, if you cant find anything wrong there then remove the main caps 1 at a time and check the bearings there too, refit it before removing the next one.
if you find a failed bearing you need to try determine what caused it, might need to measure the crank to see if its the correct size for the bearing used.
talk to your machinist that machined the engine for rebuild to see what they think caused it.
if nothing is found get some new bearings, what brand did you use? maybe try a different brand.
i wouldnt drive it anymore or the cost of a new gasket for the sump and some big end bearings might turn into and new crank
You guys are gonna hate me. But i have to post this up incase anyone else has the same problem:
The nuts holding the turbo to the exhaust manifold were loose. That sound was obviously the exhaust pulses escaping once there was back pressure on the turbo. I tightened them up and they were loose within 40 km! To solve this, I fabbed up some little "tabs" similar to the ones that come stock on our RBs, that you bend against the nuts to stop them from backing off.
Thanks guys :P .
Edited by ST240
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
