  • Replies 313
Posted Images
Matt, awesome!! I always look to shoot something as simple as that, but havent found anything just yet...
Sidd, nice lighting! I did my first model shoot today, not quite us your your standard yet but hopefully a few years practice will get me there.
First shot I've processed:
Not the best, but a start :)
Its a good start and WOW a bikini shoot for your first time!!
Not sure if that location works to be honest. Finding the graffiti distracting. What do you think?
What did you think of the model shoot? Something you want to keep doing?
Haha, was a bit taken back when she started stripping off :)
Yeah, I think it is a bit... Only reason I chose it was the "f*k the Police" on the wall, which I thought would have been cool. Everyone looks at me funny when I say that, so I could just mention I respect the cops, but thought it'd work as a backdrop for a car shoot.
Probably worked better for this:
We did move around that area though, this shot is my favourite so far:
Yeah man, definately keeping at it! Cars and landscape will always be a favourite, but nothing wrong with branching out a bit
Yup i like that shot also, but i want you to improve and so im going to tell you that a bit of fill light would have been great. You can just see her right eye. Maybe a bit of PP work can fix this up also.
You got a reflector? Its the best investment and it wont cost you much at all.
Can i have a bit of play around with the image to show you what i mean?
nice start with models (She's not bad either :banana: ) I think people really demand extra lighting if you want to pull off that special look. It's a nice firm start! good comp and ideas. also... boobs are awesome.
Sidd, the more advice you can give me the better! I'm always more then happy to accept it. I was wishing I had a light/torch/flash/reflector at the time. In hindsight I could have used my flash gun...
Go nuts with the editing. If you want the original photo i can email it to you when I get home.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
