I figure some one has put the two side by side at some point.
I'm looking at a R32 GTS4 currently and was considering swapping the rear guards for the GTR items . I have worked on more GTRs that the GTS4 so I'm unsure on panel dimensions and whether or not the rear guard swap will actually work or not. the one I'm looking at has a bit of rust around the rear window and in the lower rear guards.
doe anyone have a book of body dimensions for these? (or a panel repair manual for a GTR.)
I want to see if its doable or not without frigging around with other aspects of the car. the roof will have to be done as well as it has a rust spot in it.
thoughts?
https://www.sau.com.au/forums/topic/335665-32gtr-vs-32-gts4-panel-questions/
  • Replies 87
I am researching it at this point. I hava rough idea on getting the panel work done and I know what parts are involved via FAST and the costs associated with getting them. (i'm on fairly good terms with a nissan dealer for parts.)
rust line - mid rear window left side where glass meets body
bubble rust mid rear window right side similar position
rust spot - lower rear left wheel towards the back.
roof is a given as it has a factory sunroof in place. every car I had with one of these had a rust spot somewhere in it.
rest of it externally appears fine. paint is faded but you get that with any car of this age that has been outside for a bit.
As R32 GTR front cuts are brought in, ask a front cut importer for the unwanted left over "rear cut". Parts galore to complete the repair. I'm GTS 4 lover, hope to see another on the road.
I know a fellow with a yard in osaka. parts probably will not be the issue here. good tip though. have already checked with nissan and the parts list I gave them came back good with nothing unavailable. prefer new stuff as I tend to build cars , keep them and drive them for quite a while.
R32 GTS4-t btw so a poor mans GTR.
all r32 GTS4's are turbo Chris :D
you can cut the rear guard out and weld in the replacement ones, as the chassis is the same dimension-wise (R32 GTS4 coupe that is). We use the same measurements for both on the rack when pulling em straight. I'll shoot you the measurement diagram via email in the next couple of days.
Unless you're talking about an R32 GTS4 sedan, which is a slightly longer chassis.
shan , no it is a coupe. negated that bit. thought that there was a NA variant of the thing. I have never worked on a GTS4 mainly GTR's in that chassis so I do not know a lot about the variants of it.
dimensions would be good if you have them.
Yes, pretty sure they also came out with the Rb25 N/A.
That's the R32 Rb25 (not the R33) so top feed injectors and no VVT.
Nah I don't think so, not in the R32 anyway. If you're thinking of the R32 GTS25, it was RWD only.
The RB25DE + AWD combo was used in the R33 GTS4 though.
Congratulations, as a fellow R32 GTS4 coupe owner, they are a fantastic purchase. As described on this forum -"the ultimate tinkerers car". When are you getting your adjustable toque split controller? I've bought a Stagea block for a 25 det upgrade. Will be keen to follow you progress. Any one can check book a GTR.
Oooh so it's all doable, nice mate!
About farken time :D
yep had a GOOD look at rohans car today. that spot is a guard issue. so we are go. still have a few minor details to sort out before it pops up at the workshop.
doing the RB25DET thing anyway. RB20 is catcus as I understand. I have to do a bit of body work on it first (well pay someone to do it- thats not what I do for a living.) before I fiddle. TSC - once I'm happy with it and it behaves the way I want it to - THEN I will do it.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
