I noticed this fan when I installed my FMIC over the weekend. What is it used to cool? I went for a drive at lunch but it wasn't operating when I stopped at Subway. And yes, the engine & A/C were still on. Pic below shows the fan in question.
If someone could let me know what it is used for, that would be great. I have a Series 2 RS Four-S.
Cheers,
Adam
https://www.sau.com.au/forums/topic/335794-thermo-fan-in-front-of-my-radiator/
Have you got your front bar etc back on? I had to get a slimmer aftermarket thermo fan whem I installed my fmic.
Yeah I got the front bar back on with no dramas. The FMIC is mounted on a slight angle.
I think it only comes on when your coolant reaches a certain temp, even with my aircon on I have never seen mine operating.
Ditto, it supplements the clutch fan.
You'll probably only hear/notice it turn on when it's a 40 degree day.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
