  • Replies 119
New wheels and springs installed today
Advan GT
20 x 10 front
20 x 12 rear
with 285 and 335 Michelins
Also fitted 1in lowered swift springs...these springs actually lowered the car 3/4in at the front and 1/2in at the rear.
Pics dont do it justice...looks very fat on the road.
Thanks to Michael at Acute Performance in the USA for a perfect transaction on the wheels/tyres and springs
I have also just done the 2012 front end conversion
Looks great. Is there any rubbing with the wider rubber? Do you have the offsets?
can you comment on ride of the swift springs vs stock? are they the regular or spec-r's
ive had my swift springs sitting in my garage for months now (my second set, as i chickened out and sold my first set to a member here who didn't end up fitting them either), and worried it'll ruin how well damped the stock '10 ride is on non-runflats
Edited by domino_z
Nice wheels. Michael from Acute Performance is great and he seems to be able to answers emails at all times of the day lol. Don't worry, I didn't order your wheels =)
Looking forward to your response regarding the springs as I am looking to lower also. Looking at either the swift springs or the KW sleeve kit.
I'm not looking to order those wheels either but I am interested in whether or not there are any clearance issues with the tyres, as I also have Swift Springs fitted.
I have had the springs on mine for almost a year and would say they make the ride a fraction firmer than OEM in each setting. I've had no problems with them, the car seems to handle just as well as before but I don't track it so maybe there are differences there when the car is pushed real hard.
I'm lucky in that I can get in and out of my place without worrying about scraping but you do need to be much more aware of the lower height in general driving. Having said that I haven't touched anything since they were fitted. The car looks heaps better lowered and I would definitely fit them again in the future. Domino you are welcome to take my car for a drive next time we meet up, if you're concerned about ride quality.
  • 1 month later...
Spent some time today preparing the GTR for a trip to Willall in Adelaide.
Im doing the 1350km road trip from Wollongong to Adelaide tomorrow... Willal will be fitting everything below (turbo installation is an engine out operation) and tuning 98 and E85.
See you Saturday morning Martin,,,if I dont die from boredom driving across the Hay Plains..
Below parts arrived today...(I had the turbos already)
Titanium turbo downpipes, Kakimoto 80mm cat back (my Willal titanium system suffered a major wack on a ripple strip at Wakefield)
and Cobb 76mm intakes.
Kakimoto fitted
Willall is doing a speed density tune.,...no need for the MAFs so we machined up these cool little MAF block offs...I will fabricate some new pipes when I have a chance...these had to do with the time frame I had.
Kakimoto tips :-)
stock wheels back on for the drive to Willal
Edited by Speedah
A few pics from the road trip to Willall..
After 4 hours I still had 993km to go
this is pretty much it for 95% of the trip...I found the South Australian speed limits to be high...110km/h zones right past residential driveways....the limit would be 70 in NSW. The cops also seemed pretty relaxed....I had the cruise control set to 123km/h (GPS speed) in 110 zone and on 3 occasions they didnt come after me.
finally arriving at Willall in Adelaide....after discussions with Martin Im going to add some larger titanium lower intakes to the turbos (replacing the restrictive cast factory pieces) and install the latest "Launch Control 5" transmission mapping from the 2012/13 GTR. Willall will only need the car for week...will post results here when complete.
And now time to relax at Adelaide airport....I have a 2 hour wait for my flight :-)
Looks like fun...good luck with the mods.
With your Advan/Michelin combo: is there any rubbing on the guards?
the only rubbing I get is when taking steep driveways at an angle (which I need to do because of the now lower front clearance)...other than that its perfect
I love these in white, looks fantastic and sits beautifully with the springs. Wheel combo is sick!
Nice build up keen to see how it turns out and holds up.
Fit a Syvecs at the same time, since you are doing everything else :)
I would have but no cruise control with the Syvecs...Ill get the Syvecs when I harden up a bit
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
