  • Replies 119
  • 2 months later...
Hi ho Hi ho....its off to Willal I go...
Jumped in my car yesterday after having driven it 1/2 an hour earlier with no hint of what was to come.
Started it, shift to reverse, dash lights up like a Christmas tree with faults and throttle input does nothing...car wont move.
AWD system fault light is on (see top right below) along with check engine light.
Plugged in my Access Port and found code P0847
Had a look at the GTR service manual...code is the following...
Shit....doesn't sound good
Called Martin at Willall....common problem, factory pressure sensors shit themselves. There are 3 in the transmission and are not accessible.
Needs trans/diff removal and transmission disassembly to repair. I have my suspicions that the sensor is actually OK and the pressure is in fact low from a blown seal.
What pisses me off is that this failure has nothing to do with any mods to the car...it happens to bone stock R35s. If my car was stock I could take it to Nissan and they would replace the complete transmission under warranty.
So, car is being shipped to Willal on Friday...while the trans is out will do some bullet proofing mods.
All going well Im hoping to travel from Adelaide to Melbourne Saturday 2nd Feb, stay the night and have some runs at Heathcote drags on the Sunday (there are a few R35s going for runs). Heathcote allows sub 11 sec passes with no cage...will be good to have a play with different levels of the launch control and better my single pass 10.62 at WSID
This is the first and only fault I have had with the car in 2.5 years and I have absolutely flogged the arse out of this thing....cant complain
Pretty standard failure. Talking to a few of the boys who do some work here on the West coast, they all seem to do it between 25,000-40,000kms. Sounds like you got to the very limit of age / kms before they let go.
'South Side Performance' now do complete plug-and-play sensors for the R35 as it's such a common problem.
They're only $200. Your biggest expense will be labour:
http://www.sspperformance.com/product/gr6-transmission-pressure-sensors-/
hope you can make it to Heathcote Kev
seeing what you can run with mod'd turbos vs my full bolt on stock turbo same day same track will be a great comparison for everyone (including myself) who is on the fence whether to take that next step
great opportunity to upgrade the trans - im still on the fence whether to do this as preventative or wait till something goes wrong
Speedah did you try the Warranty path with Nissan???
Also another thing, what did the 2011 front end conversion set you back??? I'm considering doing this myself with my 2010
Yes, I talked to someone at Macarther Nissan who was very helpful...told him the full story. He explained the proceedure they have to go through to gain approval (from Japan I assume). Short story is the car would be there for a week or two while they diagnose/wait for a decision then I would be charged $600/$700 to then to say they can't help me.
Im not too worried...I would rather put parts in it that dont fail. I was very fortunate that it happned inside my workshop. A week ago I was driving in the Sydney City centre during peak hour...I dont know WTF I would have done if it decided to pack it in there.
Edited by Speedah
Ill be there...try and round up as many R35s as you can.
Stock wheels back on for Willal trip no. 2
Ready to go. (car has now been delivered to Willal)
If you need to transport your car from Wollongong/Sydney area interstate by someone that actually cares Mick is the man. Some of you may be familiar with his 7.4sec Torana MV454
I seriously hate transport companies all together. While I didn't have issues with CEVA, I had a fuel contamination issue a few weeks back and the GTR had to be tray back transported to Moorooka Nissan for draining. I made sure I taped up the front lip (2 layers) just in case it was scratched. Sure enough, the tape was fully scuffed when I picked it up from Nissan the next day. Luckily there was no damage.
The transport used was the GTR Roadside Assist preferred - Wilson Transport - in Brisbane. I do not recommend them, nor will ever use them again!
Edited by Wardski
Have they fixed this pressure sensor problem in the later model R35's?
Nup. Transmissions are almost identical in that regard all the way to 2013. With all GT-R's its not a matter of if it will happen, its more like, when it will happen :P
Edited by Wardski
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
