I am using Type R, supposed to be rated to 600hp, can be plumbed back, also it has facility pressure line from in front of the throttle body, to help it lift (lower one in the pic) - good for high boost. Holds fine with 1.7bar.
Bought if from greenline for around $300, here they retail up to around $600.
Have also heard the Tials are good.
https://www.sau.com.au/forums/topic/33617-bov-for-300rwkw/#findComment-673839
1g for a blow off valve? pff as if.
I already got a turbosmart 45mm racegate on mine
:werd:
After spending $700 on my pro-gate (new in box)
A grand for a BOV is bloody ridiculous
The Type-R sounds good then by the general consensus :)
https://www.sau.com.au/forums/topic/33617-bov-for-300rwkw/#findComment-673853
i use a type r they are great just dont expect to do little image psshhhttt's past people as u need to see at least 14 psi to get the things working, which is good im just warning the ricers out there!!
https://www.sau.com.au/forums/topic/33617-bov-for-300rwkw/#findComment-674651
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
