hi guys i am about to do the 100,000 km service on my stagea and was wondering if all the RB motors use the same water pump. im pretty sure the RB26 is the only motor that is different.
i am sourcing all my parts through my uncles workshop but some of his part books are a bit old.
any help would be greatly appreciated.
https://www.sau.com.au/forums/topic/336281-water-pump/
you will need a NEO (R34 Gtt) water pump, different(and dearer) to standard rb25 rb26, part #21010-AA527.
eg http://www.kudosmotorsports.com/catalog/ni...25det-p-38.html
http://www.skylinesaustralia.com/forums/in...t&p=4533449
https://www.sau.com.au/forums/topic/336281-water-pump/#findComment-5439927
is there anything in particular that makes the NEO engine water pump different to the others.
i imported my car from synergy a few years ago and while i was in there last week they said they use standard RB25 R33 water pumps as the only difference was a 10mm locator bolt hole was missing.
just trying to save some money if possible as RB30/25 water pump i can get for about $80.00
https://www.sau.com.au/forums/topic/336281-water-pump/#findComment-5439974
from what ive read, Nissan addressed some water flow issues with earlier pumps with higher flow at mid range rpm on the NEO pumps through their redesign. I suppose its like oil, whatever the budget can allow, but NISSAN wouldn't have redesigned it without a reason.
https://www.sau.com.au/forums/topic/336281-water-pump/#findComment-5440011
Given the work required to change it - you'd be silly not to do it at the 100,000km service time.
+1
Your belts are off and you've drained the coolant anyway to remove the radiator ... its just so easy to do the waterpump too at the same time.
I am doubtful tho about the Neo waterpump being different. Is there a link to some info confirming this?
https://www.sau.com.au/forums/topic/336281-water-pump/#findComment-5440073
NEO pump is different, its been covered a million and some more times
How is it different? Where is the source? I'm trying to find specs but they don't exist. Just spoke to Nissan and even they don't know how they are different.
What I have found is:
Part #21010-70TY5 ($110) - for R32 GTST
Part #21010-58S25 ($120) - for R32 GTR
Part #21010-21U26 ($175) - for R33 GTST/GTR, R34 GTR, and series 1 Stagea
Part #21010-AA527 ($260) - for R34 GTT, series 2 Stagea
Part #21010-24U27 ($380) - for N1 Skyline GTR
Note: they say "for" not "fit", so you could interchange.
https://www.sau.com.au/forums/topic/336281-water-pump/#findComment-5440321
More info sourced from guys who've done the comparison overseas with pics ...
One source claims the standard RB25DET pump appears shallow, whereas the Neo water pump is deeper, but there is no comment on the blade design/difference. No pics were available to back it up.
Below is an N1 water pump vs OEM RB25DET pump. Blades are obviously different:
The N1 flows less than OEM for a balanced high RPM setup.
The OEM flows more than N1 and is good for street and light track time.
Above is the N1 compared to an EOM Neo pump.
One source says the NEO pump looks like Nissan addressed the flow issue they were having at mid-high RPM (again, no pics/evidence to support this).
Below is a pic of an RB25/RB26 pump (non N1/non Neo)
:cool:
So ... best way to solve the argument is to get our hands on the 3 types of pumps (OEM RB25, OEM RB25 Neo, N1) and measure volume/capacity/depth, and blade specs and take pics.
So who's got some spare waterpumps lying around? :P
https://www.sau.com.au/forums/topic/336281-water-pump/#findComment-5440374
The only difference I know about is in the positioning of one of the mounting bolts. Some aftermarket pumps cater for this by having a slot there so it will fit all applications. Pumps are supposed to be good for 200.000 so if you are confident about the speedo reading and pump is OK you could leave it til the next belt but if you think speedo may be wound back then change the pump anyway.
https://www.sau.com.au/forums/topic/336281-water-pump/#findComment-5441454
If I'm not wrong, the N1 will fit most variants due to that oval shaped hole. As mentioned above, its the mounting bolts thats different. I'm not 100% sure though. Lesser blades on the N1 was for more flow? isnt it? If they're all spining at the same RPM, the one with lesser blades should flow more.
https://www.sau.com.au/forums/topic/336281-water-pump/#findComment-5442105
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
