Realistically, they can do whatever they like. It is your word against theirs.
To get behind that trim piece, you can simply undo the screws holding it in behind the ash tray and above the speedo. From memory the rest of it is clipped in. Be careful though, it is fairly easy to crack. You also unclip the gearboot and there are a couple of screws for it under there too. Logic will prevail with this one if you take your time..
Best bet is to feed it into the glove box, that was its reasonably out of the way and you can still get to it. Generally if they actually look in your glove box you are up the creek anyway, yet having it there will minimize the attention.
GL
i want to hide my boost controller?
how do i get into this compartment see below?
You do realize it wont be hidden now that you've told everyone where it is... ;)
May as well just hide it in your ashtray like normal people..
Are cops allowed to physically touch any parts of the car?
Ive heard they can even touch your bum :blink:
It all depends on how you drive and what you are doing............like me, many ppl have SAFC and boost controllers mounted on the dash/steering column/console and have no problems with it.
I've been pulled over and they have looked at the car while I've done a RBT and then let go with no problems. But then again I don't use the road as a burn out pad or a race track.
So wanting to hide it is sort of suspicious???
not sure where u come from , but being defected every time you move isn't very fun.
and when cops look for a boost controller they would usually look from the engine bay and look for vac lines running all over the place
people usually use coloured shiny vac lines they buy from autobarn etc so its easy to spot
use blank simple lines and try to make it look oem. but the vac lines always run to a solenoid of some sort, so thats the easiest way to find it with the controller hidden or not
i want to hide it inside the dash/steering wheel/console area, how do i "unclip" it to get in there?
In my R32 I cut the ass out of the ashtray and mounted it inside there, when you flip it open it looks very tidy. Hid the solenoid underneath my AFM so that you need to unbolt the entire POD assembly to be able to even see it, no cop is ever going to find it.
All the wires and vac hoses are cable tied underneath it as well.
Edited by Rolls
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
