Saunsw Dinner With Jim Richards @ Trackside Restaurant
keen for 2 seats if still available. let me know and I'll transfer in the next couple of days. sound be a grand ol time. I even have a new 32 GTR so I can park in the fancy parking. :blink:
  • Replies 83
that leads to my next question - can i reserve my car space for my r32 hihihi :D
Alan Heaphy is also a guest speaker on the night too! ;)
...former Project Manager for Gibson Motorsport over a 14 year period! :)
(BTW Andrew, there'll be more of these on in 2011 - stay watching!)
  • 1 month later...
Just reviving the thread as I may have 2 spare tickets on the NSCC table. If anyone is interested in coming, I may have these tickets on offer. Please just pm me.
PM sent
  • 3 weeks later...
OK peoples, there is just over one week to go to this incredible event, so attached below is a menu as to what will be served on the night. As you'd be aware, you're paying for a three-course meal, so you get to choose one item from each of the three sections.
As some people have certain eating habits, allergies and intolerances, could those in this situation please send me a PM as soon as possible, so that the staff know ahead of time what may need to be taken into account. Please include a full name for the person(s) affected, and what the dietary requirements are. (Please be reasonable, though...)
dinner_of_legends_menu_1_.pdf
UPDATE to event; Gibson GTR wont be attending, its got a gearbox that wont play ball and Holinger dont stock parts for it anymore so they're making it from scratch.
Will have the GIO GTR instead, this is totally out of our hands and as most of you are racers, im sure youll all understand what its like with racecars :)
Guys and girls, don't forget to let me know BEFORE lunch time Saturday if any of you have any special dietary requirements as above. The PM system is working now (this was incredibly bad timing, but there's not much we can do about that), so please let me know...
Yes i only eat things sprinkled in a fine coating of Diamonds.. Its the most balling S%it u can do to your food!
Yes Dave, your food will be sprinkled with ground-up glass (can't afford diamonds, unfortunately), so you can fully appreciate the taste of the food as it goes down to your stomach! :P LOL
hi all,
due to unforeseen circumstances & family commitments - unfortunately i cannot attend this event :(
hence, my ticket is up for sale - i guess its 1st in best dressed.
pls send me a pm & i will respond with my bank details.
regards
marko
Good News - Bad News!
Umm...
The Forbes > GIO R32 GT-R will be present on the day :banana: for viewing - for pics. So bring your cameras!!! This may be covered up by dusk BTW.
The Ashwood > Winfield R32 GT-R won't be present on the day :yucky: due to a gearbox replacement.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
