  • Replies 50
There seem to be quite a few good ol' v8's out there that can pull fast quarters, in the 9-11 sec bracket and doing it seemingly effortlessly when I have seen it at Willowbank.
It has just caught my attention and it seems there is a fair amount of drama involved with doing it in a 4/6. Lotsa noise and no guarantees kinda atmosphere.
These old fords I was getting to look at where nothing special. I was with mates of the owners and they were all a pretty standard setup with 2 speed boxes, good low grunt and juuuuuust the right suspension setup and tyre pressure (soft rears, really soft). Hell even a panel van did a 9!
'Lines tend more toward circuit setup in my limited perspective and obviously the 60 time is critical so if you were to trick the box, raise the stall and work the suspension it would be interesting to see how the stock power output would do over the early part of the course. Just seems too many import owners get the suspension and 'box setup wrong, more a street tuff setup.
  • 1 month later...
Once you get into the 12's (high/low) with mph over 120, tyres are the clincher...
On street tyres (ie. falken azenis st115 - which are sm_limpy.gif), the best I've run is 12.3 @ 124mph - with a 2.35 60ft...
Going by the fact that for each 0.1 sec at the 60ft line you should be able to make up 0.2 sec at the other end, a 1.85 sec 60ft time (in theory) should be worth a full second at the other end of the track.
The thing you've got to remember, is think about how quick 0.1 of a second is. It's about the same amount of time as it takes to blink!
The cheapest way to get an 11 sec 1/4 with the smallest amount of power, is a set of 90/10's in the front, 70/30's in the back, a 4000rpm high-stall, slicks and a set of front-runners!
Cheers,
matt
What gearbox would you put behind a rb30det? Im in the process of starting a new project and ive decided its got to be drag foremost (over daily driving) it will still be a 'street car'. With this in mind ive decided on auto, can they do a jatco 4 speed which retains 4 speeds and can hold 500 rwhp. Or should i be looking at a turbo 350 with adapter plate?
first of all, if you're looking to build a car for drag racing, why are looking at retaining the crappy 4 spd Jatco?
depending on what times you're after, you'd ideally be better off going for a Trimatic or even a 2spd Powerglide :kick:
secondly,
if you're really dead set on the idea of the Jatco, i believe Yarrey Valley Autos are the guys to talk to.
Ummm sorry rev210 but how is it possible for them to be achieving these times on street tyres. As far as I know only two GTR's in the country have even acheived mid/low 9's using nittos and they are Keir Wilson and Munro. They get traction problems in their 4wd equipped cars so how is it possible for the v8's not only to grab traction but finish the quarter with such low times on radial tyres. (I am trying to say they must be using slicks)
I was at a drag event at Willowbank 2 years ago and one of the guys I was with had a panelvan...V8 obviously and rear tyres with tread. Didn't take much notice other than that but they were running pretty low pressure. Ran a 9.? second pass as easy as. I was rocked, but this thing didn't like corners.
The V8 brigade have the drags sorted so there are a few things to learn off them.
I had a vl calais turbo with a 5 speed RB30DET box in it and it handled 220rwkw easily. But i went through clutches and diffs a fair bit. U put a good driveline on it, over 200 kw and ull be scaring alot of the nice cars on the road. ( i miss mine :) )
go to your local drag strip, then we will have this discussion again if you think there is a point to it.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
