Hey all,
Yes it is another bov question, but not a gay one... lol
Basically the car was tuned with an atmo bov, now if I change it back to recirculate (using same bov) will it affect the a/f ratio as there will be more air going back into the intake then tuned for?
Thanks in advance,
James
https://www.sau.com.au/forums/topic/337306-plumbing-back-bov/
No leaks.
When I got the car it already had the atmo bov and was tuned with it. But I don't want the noise so hence me wanting to go back to plumb back. At the same time don't want to mess with the air flow. On top of that don't want to pay for another tune just to have it recirculated.
Edited by GT888
plumb it back. if your really worried chuck it on the dyno after and make sure afr's are safe. aslong as it wasnt leaking tho it wont change anything other than the massive overfuelling you'd currently get when backing off
After plumbing back I have noticed that when going on high boost then backing off it revs out a little by itself. But that's only on high boost between 1-1.5 bar. I guess besides wasting a little more fuel it'll help me keep my revs up when shifting gears when racing lol. I have the Apexi turbo timer which has an a/f digital readout, but don't understand the numbers.....
Edited by GT888
Your Apexi tt will be reading the stock narrow band O2 sensor so any information about afrs will be useless anyway.
^how do you know?
Adding a atmo bov to a stock tune makes it's run richer
So when a car inls tuned for an atmo bov Nd switches to plumb back why wouldn't it run leaner
You could explain yourself instead of posting like your mr know it all
^how do you know?
They only run richer because air that has been measured is being dumped. Fuel is still being pumped in for the missing air, ergo a richer mixture.
No dumping of air, fuel amount is correct for air going into engine.
Simple
Simple
But the car has been tuned for not having that air going back into the engine, therefore there will be less fuel in ratio when plumb backed without another tune to compensate... ???
depending on your driving style i would be checking the tune with a wideband, on a dyno its mostly on throttle then backing off, whereas on the road like climbing a hill boosting then backing off a little then accellerating, this will cause the BOV to release and change the mixtures,
if it was a drag car i wouldnt be too worried as its flat out all the way only backing off for gear changes.
  • 2 years later...
i have a quick question regarding my stock bov...
i recently ugraded my inlet pipe with an aluminum pbm pipe but it didnt come with a nipple to recirculate my bov. i wus wondering if it would be ok to recirculate my bov maybe into my intercooler plumbing? since the maf has already read the extra air from the bov ...would the car run normal as it did if i did the plumbing somewere else besides the inlet pipe after the maf?
i know this is an old post but this would help lots .
thank you.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
