Hi guys
i have a set of Autech 18's for sale.
specs are:
18x8 +30 5x114.3
Come with Bridgestone re030 tyres but are quite worn.
bit of gutter rash, but easily repairable.
Not buckled and clearcoat is still great unlike others i have seen.
they come off a Stagea Autech AXIS
would look great on most nissans!
see pics. more detailed ones to come.
PM for further details.
located in Knox. Melbourne. will meet or drop off around Melbourne.
will send interstate at buyers cost.
$900 OBO
Awesome looking m35 mate
wat rims you replacing the stockys with? Or it's a secret?
Do tell!!!
thanks mate.
I'm thinking a charcoal set of TE37's in 9.5" wide to fill the flares a bit
Im thinking bout it... just dont know if i get these will i regret not getting 19's... maybe i will flip a coin!!
will let you know my choice asap.
sure thing Matty
they are nice wheels, you wont regret it.
your in Sydney yeh?
Edited by garetb16
open to offers guys.
dont be shy
Know how much they weigh? How would the +30 go on a C34 stagea?
Oh, and can you get a close up pic of the rims ... so I can try photochopping onto my stag >_<
Oh, and can you get a close up pic of the rims ... so I can try photochopping onto my stag :O
hey mate,
they will go onto your car no problem. should come some more than standard, Im unsure of the standard C34 wheel specs.
im taking the wheels off the car this weekend. so i will be able to get some decent pics of them then for you.
you are welcome to come and trial fit if you like.
unsure of weight. but i can weigh them this wekend
Edited by garetb16
Oh, and can you get a close up pic of the rims ... so I can try photochopping onto my stag :D
Ruby my 350Z rim`s are 30+ so you see they look good,so will be sweet,i would have had then but 18`s :P ,
sorry only front veiw no side on i will take some ,
sure thing Matty
your in Sydney yeh?
I am but brother lives down your way.. I had a goos thought i know i wont regret it but i think im just gonna wait till my rubber wears out and get some 19s then..
sorry dude.. plus i need to put some money toward this dump pipe im hopefully getting..
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
