First car.. R33 or R32 ?
Run a 7 psi wastegate and wastegate boost and it might be ok on the stock ECU. Basically you cannot run past the last load cell by a significant margin. -
If there's no stutter in fuel pressure when the issue occurs then I'm not sure it's the fuel system necessarily. Do you have any Nistune logs when the issue occurs? -
you would be better off installing a Haltech (or similar) with a wideband O2, run the base map with O2 feedback on at gate pressure. -
Thank you for the feedback bro. Looks like it’ll have to stay off the road till it gets an ecu
