  • Replies 44
Should take no longer then an hour of labour if its a bolt on exhaust.
The process however, you may need to allow 2-3hrs as when you drop off the car the mechanics need to wait for the stock piping to cool down before removing. Usually charge around $80/hr so allow yourself at least $100 to be safe.
You could do the install yourself, saving you the cost of someone else doing it.
It would also save you the time of organising it to be done, and you can do it when you want.
A straight bolt on system is just that, you wont need to remove anything else because it is in the way.
Just unbolt at the flanges and remove the hanger rubbers from the old system, swap them over and the bolt in the new system into place.
As long as your not getting extrators it should only take a few hours.
I was gonna get these, put off by the 12 hr install time people speak of...
Ill have to do with HFC resonated and y-pipe!
OP: Google the install and do it yourself. There is nothing like knowing you did something on your own. !
Give Aaron from import monster a whirl,
depends on exchange rate etc but allow $2k-ish for product and delivery.
Import Monster Pty Ltd
3/6 Wigan Road
Bayswater VIC 3153
(03) 9008 0031
Edited by TUFF_350
I got mine from Hi-Tech Mufflers (Sydney)... Cat-Back stainless steel.
I can't remember exactly how much it was but was around the $2k range.
Left it in the morning. Went to the gym for a couple of hours and it was finished.
I felt power gains as soon as I took off from the garage. But I didnt get a dyno done.
Sounds good when in full flight but just had a nice hum when just cruising.
I guess just depends on how much noise you want to make.
is it much louder than stock at idle and cruising? I hear hitech supposedly has the best gains power wise, but is not much louder than stock...
always loved the HKS but i hear they drone so that put me off... atm looking to import motordyne from the states, seems as good as HKS but without the drone
Yeah I was really impressed with the power gain. Felt real good.
To be honest at idle, its not much louder than the stock exhaust maybe 2 db louder, but even louder on cold nights and you'll definately notice the exhaust when starting the car. I really like the fact that I can take a long drive and not get a head ache from it but still turn heads when I launch it.
Check out my recent Wakefield Track Day video:
Silver 350GT... First minute of the video you'll see me flying down the straight followed by 2 different cars with louder exhausts. Its a good comparison. Turn it up to hear the difference.
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
