hi, just got my new car........How much oil goes in when you fully drain it and new filter.......getting shoulder surgery tomo so i need to service it tonight but i don't have any books that specify how much oil to use
cheers fella's
(i did a quick search but came up with nothing and i;m running out fo time!!!)
  • Replies 73
Fill til it comes out the filler plug...that's what it's there for. For obvious reasons you won't be able to put any more in!!!
where is the filler plug? never heard of that...but anyway i thought it was 4.8l and 5l is good to put....could it be diff for rb26 or its the same for rb25 too...
Might be different on GTRs but it's usually on the side of the gearbox, not far from the slave cylinder.
Just put in 4L, start the car, switch it off and keep topping it up until its at full. 5L is far too much.
I can get 4.8 - 4.9 L perfectly in the middle of the dipstick if I jack up the back/passenger side of the car and drain out everything, I dont think 5L is way out there.
never knew that...ill check of that now in the weekend...would it be in other cars too? like commodores?
i've always found in the stag s2 rb25neo turbo, it fills my draining tray including the filter to about 4.9 - 5l right on the line.
(depending how much spills in the process on the front diff)
and my dipstick is always bang on the H mark.
now you've just reminded me i've gotta do a change this weekend.
Edited by Stagea_Neo
I change mine Every track day I put in 5l , Been doing this for 2 years now ... :blink: runs sick
I always filled 5L too...never hade any issues...when Jezza-gtR said 5L is too much i started to get worried..lol...thanks for confirmation...
the sump takes 4.5 litres
but for a track day it is advisable to overfill by 500ml - 1lt to help prevent oil starvation
i usually just throw in 5lt
OOPS was talking about gearbox fluid lol. Got it confused with another oil replacement thread :rofl:
OOPS was talking about gearbox fluid lol. Got it confused with another oil replacement thread :)
:yes: ..you got me all confused and was looking underneath the car like a dumb idiot...lol...y didnt i read this thread before i did it...lol...
sorry guys, didn't wanna start a new topic..
but what oil do you guys use?
sure there is couple of threads about what oils to use...do a search you might be able to find more info...
to answer your question i use castrol edge 10w-60 since its been recomended by my mechanic...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
