You won't hit any where near 300kw on the GT-RS unless you use nitrous like me lol.
Also are you sure it is running on 10psi? The stock HKS actuator is a 1 bar one.
i recall the the boost before it was tuned was "10psi" which i think is the stock level as you may remember PM-R33 from a while ago.
today when i picked it up it hit about "16psi" which i assume is now why i have boost.
Looking at this shootout graph from 70hp@10psi is a steady climb to 245hp@35psi_g then climbs to MAX:258.9hp@37psi_g
  • Replies 44
do you have a boost gauge?
if you are running 16psi you should be getting anywhere between 300-350rwhp
PM-R33 im assuming the gt-rs is like the gt2835 and that the actuator is adjustable if so the tuner could have turn it down to 10psi if the fuel pump isn't working.
Luthor666, no one can give you a direct asnwer on here as they didn't tune the car best if your not happy is to ring up tuesday and ask what is the go what they tune it for? what psi and why it is not making much power they will be able to tell you what is the go.
failing that just take it to another workshop, however a working fuel pump and ebc is a minimal if you want to push some high numbers. HKS rating on the GT-RS is 400 or 420PS, 400hp = 298.4kw, which is really push the turbo and i dont know if it would make it. If you really want the figure try 22psi and see what happens lol
this is my "now problem" the sheet says next to nothing and is almost embarrassing but on the way home i thought hey its only responsive, but feels "weaker" than before, then i hit a straight and got it to about 4000rpm and then BOOM instant boost (not having it for so long the boost almost scared me) but then i thought this is Great! but my dads is rated at 224.6hp with "no" major mods what so ever but mine has had countless $$$ spent and only 258.9hp could maybe the sheet be wrong?? because it feels better than it says?
Not sure what I am ment to be remembering?
So wait, what? So what boost is it running? You are all over the place on qouting the boost it is running.
I aint assuming anything. I have a GT-RS and therefore know that it has a 1 bar adjustable actuator.
That aint rated at the wheels. The average figure for a GT-RS is around 250-260rwkw. Most I pushed out of mine on the shithouse Microtech was mid 260's without nitrous.
Dude just post up the dyno graph otherwise no one can help.
Edited by PM-R33
I have a GT-RS too, and I pulled 338rwhp (252rwkw) on 15 psi.
Have thought about bumping the boost up a little more but meh, its fast as it is, I'm not willing to melt things for 10kw.
260rwhp aint right unless something is screwed.
months ago YOU (PM) were the one that advised me on what i needed to do to get my boost back and running again
now i have taken that and this is what i have
BEFORE:
10psi (stock)
almost no boost at all with GT-RS
AFTER:
installed injectors and ECU
tuned to 16psi
shootout sheet peaks at 37.0psi_g @258.9hp
but the numbers of 258.9hp doesn't seem right against an almost completely stock r33 tuned to 224.6hp
i will try to post it
Edited by Luthor666
Ok, so 193kw@16psi is obviously telling you something is very wrong as you can see by SoFreshSoClean's post you should be around the 250kw mark and I was about the same on that boost level.
Start by checking the obvious things: Collapsed cat, skipped tooth on timing belt, CAS failing etc.
Best bet, take it back to your tuner and discuss it with him.
Edited by PM-R33
but this is doing my head in
could this be all to do with the bleed valve and not a "proper" boost control?
it was the only thing bypassed to make it work on the dyno
Edited by Luthor666
Yeah dude my engine is stock, just have a power fc, (real) walbro fuel pump, 550cc injectors, intercooler, exhaust, pod filter, and greddy ebc.
I have heard of up to 300rwkw with a GT-RS but they seem to be few and far between..
so if the boost control is likely to be why this is so wrong, why would it read 16psi @4000rpm in forth? but feel like so much more
my only other guess is these numbers in HP should be in KW
because isnst a stock factory r33 183kw
Edited by Luthor666
Righteo so you can tell you have boost control problems. It's ramping up fairly nicely to 16-16.5psi but then falling over to about 12.5-13psi. But either way even on around 13-14psi it should be making quite a lot more power.
You can't "feel" boost pressure. You could be running 20psi but still make crap power and have a slow car if something is wrong.
If the numbers say HP, it's in HP, simple as that. You can switch everything on the dyno graph to different measurements, a lot of people like using HP. A stock R33's engine is rated at 183kw, not at the wheels.
Like I said, take it back and discuss it with them. They are the ones doing the work, if you aint happy, tell them.
Edited by PM-R33
Boost control problem is really obvious from your dyno graph, get it fixed will make a signigicant difference. Have said that I've made more power on a stock turbo, so there are other issues at play here, but need a dyno graph vs. AFRs to tell you anymore. I'm sure the workshop could tell you all of this and more is you asked :P
Boost control problem is really obvious from your dyno graph, get it fixed will make a signigicant difference. Have said that I've made more power on a stock turbo, so there are other issues at play here, but need a dyno graph vs. AFRs to tell you anymore. I'm sure the workshop could tell you all of this and more is you asked :D
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
