Carbon Fibre S2 Front Foglight/indicator Surrounds Group Buy!
Hi Guys,
I just wanted to thank everyone for the patience and understanding in this group buy.
I am very proud to say THEY HAVE ARRIVED!! I am busy packing these up for you all I will have them in the post tomorrow with delivery before the weekend.
You will receive an email with your tracking details tomorrow.
Thank you again to all of you.
Cheers,
Shane
PSI Parts
  • Like 1
Ok, I have been to the post office and they were all sent Express Post so expect them tomorrow guys.
You all should have received an email with your tracking details also.
Shane
managed to snap off one of the screw points while fitting.. im raging so hard right now lol
hopefully an adhesive helps..
Oh man that sucks. I was so paranoid about doing the same thing. Try some hardcore superglue or just don't worry about the one.
My stock ones had two snapped off from a minor prang with a roo years ago and I didn't even know about it.
wow Phil i cant believe how dissapointed i am right now with the fitment of these, i go to put the right hand side 1 on first and 3 out of the 6 tabs are about 5mm out of where there supposed to be and are no where near fitable, all the tabs on the right surround are overly to fat compared to the left side surround where the tabs all look beatiful and alot neater. i know with being aftermarket and carbon there not going to be 100% but to completely not line up is not cool.
Been waiting so long for these and for them to not fit is so dissapointing, i dont want a refund would just like a set that fits!
  • Like 1
If you have a drama send us an email with a pic and an explanation with what the drama is and we can sort it out.
Hmmm that's strange man. Mine were nearly all spot on. A couple needed a slight "push" with the screwdriver to move them a millimetre or so, but nothing that would make it not fit :(
i glued the mount back on but ended up just ignoring it since it didnt really influence the fitment
regarding fit, i found it was out a bit too. 2 points on each cover require the mounting point to slot inside, and the points on this cover are just too fat to fit inside the little circle on the foglight assemply
i ended up just trimming about 5mm off the 2 points on each cover. just used a hacksaw blade took about 10mins
  • Like 1
I wonder why mine didn't have any problems? Like I said, a couple of the screw holes were slightly aligned wrong but only by maybe a mm. And some of the holes were drilled slightly to big so I just needed slightly thicker screws but that was it.
Delljit, looks good man. You happy with it?
well i had to use wider screws, and the 2 mounting points that are closest to the centre of the car were too long to fit into the assembly's standard points so i had to hack saw a few mm off to compensate
it looks good but was a bit more screwing around than i initially anticipated
happy with the end product in terms of appearance, not as happy in terms of needing adjustments
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
