Well,
Top Secret Front and rear diffusers made 100% Carbon not the 1 layer crap Top Secret supply
Carbon Fibre Z tune lower side skirts and rear pods
Carbon Fibre Nismo Front bar ducts the 2 that go on the standard front bar
Looking at doing something with the rear wing too
There's a good start for the outside,
Just gotta make some time to do it, working on a Carbon Fibre R32 GTR dash currently
Oooh, let me know if/when you look at doing anything carbon for intake - hint: carbon pod enclosure
I got the same pods as you, and i was looking at doing something. just not sure what.
just working out the legality of pods. mine are securely bolted to the chassis with brackets, but can you still get booked for not being enclosed?
no the undertray front splitter, but if you can PM me all the parts you can do for a 33 as I want to add some more carbon to my cars diet :laugh:
Also i will have to PM you about a repair for a garage defend panel that was damaged in transport. But I will take some shots first.
  • 1 month later...
  • 3 weeks later...
Just a bit of an update
Nismo vents arrived, just molding them now and i will be making Carbon replacements. Will look much better
I've also got some GTT reverse lights i'm going to modify. LED inners in Red and White.
  • 11 months later...
So bit of an update time....
As some of you know my car got rear ended in March... stupid commonwhore driver.
I was really worried that the paint was going to be the biggest challenge but the challenge was sourcing new parts.
After tsunami's and stupid customs the parts finally arrived...
There is 3 Companies I need to give a plug to and thank them for being as patient as me during the 6 months.
1- Chris @ Audio Express My link for sourcing new parts from Japland through the mayhem of tsunami's and Melbourne customs brokers, the parts got here and now my car fixed. I have now got the Carbon bug once again.....
2- Grant @ Exclusive Auto, Newstead My link They perfectly matched the Midnight Purple III paint and repaired my car.
3- Les @ Fat Pipes, Kallangur My link They built me a beautiful new exhaust which is much better than the original Kakimoto system I had.
Here is a few pics to update where I'm up to, including pics of the new exhaust. I will get better pics when I put it up on the hoist to do my brakes.
And My next Carbon addition, couldn't find a wing that I liked so I got cracking on a custom addition.
More pics to come......
Noy
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
