hi all,
this is what i have got rb33 series 2 with new plugs new coils, return fmic, full 3 inch s/steel exhaust, running 12 psi with ecu tuned by toshi and and a gen walbro fuel pump. ( had car all serviced and radiator, water pump, fuel filter timing belt etc all replaced) now power is about 190 atw and i want about 260-270 atw
should i upgrade ecu, injectors, and turbo/hiflow my budget is 2-3 grand is this possible? any ideas would be helpful i would like your ideas no matter how little they may be thanks
https://www.sau.com.au/forums/topic/338248-r33-help/
GCG highflow is around 1700-1800. not sure bout hypergear. maybe get highflow and ecu and run on the limits of the AFM until you have the coin to get a Z32 and injectors as AFM will run out of legs before the injectors
https://www.sau.com.au/forums/topic/338248-r33-help/#findComment-5466724
For $2000-$3000 - No.
Injectors are $700-800, ECU + tune is at least $1500.
$2300 before you even start with the turbo, fitting, new dump etc. Then comes the clutch and everything else.
You need at least 5k realistically maybe more.
https://www.sau.com.au/forums/topic/338248-r33-help/#findComment-5466730
hi all,
For 2~3 Grand you can get a GT3076R in the new nissan 6 bolt housing. (I think they were for $2300). Or get hypergear to do your high flow, they can make your stockie to pump 300rwkws+. Check their thread out.
https://www.sau.com.au/forums/topic/338248-r33-help/#findComment-5466945
Not one supporting mod listed there. What good is a turbo if you have no other parts to make use of it?
As i said - its a good 5k adventure.
https://www.sau.com.au/forums/topic/338248-r33-help/#findComment-5467072
Stock GTR 33 Series 1 with below mods.
- Exhaust (High Flow) $200
- PFC (Second hand) $950
- Cam Gears (by Racepace) $350
- Tune $600
With above mods, went from 194kW to 264.5kW
All for $2100.
Everything else on the car is stock (Turbo/Engine)...
https://www.sau.com.au/forums/topic/338248-r33-help/#findComment-5467601
I had a look at that, and was wondering how it fit, as as far as im aware, the GT30R needs a 10mm spacer to clear everything on an RB20/25 with a stock manifold.
How'd they get around that one?
https://www.sau.com.au/forums/topic/338248-r33-help/#findComment-5467855
Mine was a factory OP6 high flow, every thing bolted back the way it was. the 300rwkws+ high flow I referred to was the so called "pu high flow" which comes with a .82 OEM pattened turbine end. From photos all it needed was a oil feeding line like all their other high flows. It runs on factory comp housing so I guess spacer is not needed. Have a read in their thread, lots of information:
http://www.skylinesaustralia.com/forums/Hy...ce-t261613.html
https://www.sau.com.au/forums/topic/338248-r33-help/#findComment-5470036
Whilst it makes 300rwkw, the power band is not that of say a GT30 which has a good 1000rpm extra to play with.
Horses for courses i guess and many factors one must consider when purchasing a turbo.
Yeah a turbo might make "X" power, but the real point is just how it makes that power. Is it responsive, how much RPM do you have to work with etc.
https://www.sau.com.au/forums/topic/338248-r33-help/#findComment-5470050
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
