ok i know theres topics on max boost on stock gtr turbos @ 1bar (14 psi) etc etc. and i havnt run any higher according to boost gauge in car.
but my theory is that the 2 turbos running COMBINED are making the boost thats read into engine @ 14psi.
So wouldnt this be split by the 2 turbos making half the boost each into the engine @ 14psi = 7psi each turbo?
if this is correct the rb26 engine could run on these turbos total into engine of 18-20 psi (technically) making the turbos run 9-10psi each if this theory is correct!
if anyone agrees of disagrees with this feedback appreciated.
(i am steel wheeling the gtr turbos anyway but was thinking on this theory anyways if its correct.)
https://www.sau.com.au/forums/topic/338320-gtr-boost-theories/
The inlet tract - from turbos to throttle body - is a single unit. Pressure created within the tract is distributed equally through the tract (as per standard laws of physics and fluid dynamics). So the boost created within the tract cannot exceed the boost created by the lowest boosting turbo.
In short, it doesn't work like that. If each turbo only made 7 psi, then the manifold would only see 7 psi. 7psi + 7psi = 7psi.
Flow is different from pressure, PSI is not a measure of how much air the engine is receiving.
Stock turbos make about 200kw as a pair at 1 bar (14.7psi), whereas the biggest twin turbo you can get GT2860R-10 as a pair at 1 bar probably makes 300-350kw (maybe more) only because it flows more air at the same pressure.
Picture this, what happens when your car's tyres are pumped to 15psi, and you want them pumped up to 30psi.. you set the air compressor to 15psi.. wait, what's going on my tyres aren't pumping up, they're still 15psi! Ever noticed as a kid when pumping up your bike tyres, when the tube is completely empty and it's real easy to get air in with the hand pump, but when it's inflated it starts getting harder and harder to put more air in.
Moodles is exactly right.
Each turbo is putting out 14psi, but having 2 turbos instead of 1 means that each turbo has to move half as much air to achieve the same pressure. That's the advantage of win turbo, you don't have to work the turbos as hard to get the same pressure, which means they can handle more pressure or they're more reliable. That's the theory anyways, not sure about the actual turbos used.
has been tried and tested over and over and over and over,
people thinking the stock GTR turbo's can take more than 14psi, then boom shatter the ceramic turbo and kill a motor,
then people asking oh wait maybe if i run over 1 bar it wont happen to me
Couldnt have said it better myself.
ok thanks for the responses guys!
i am upgrading the turbos to steel wheels n1 internals, then planning to up boost. any ideas on what max i could run into engine standard internals everything etc except air pods n exhaust etc.
"i am upgrading the turbos to steel wheels n1 internals, then planning to up boost. any ideas on what max i could run into engine standard internals everything etc except air pods n exhaust etc."
Steel wheeled turbos are known to be good for 30 odd psi - give it a try and let me know how u go as I hear it sounds pretty good :blink:
What upgrade turbos without ECU?
1bar is about the limit, same power as everyone else - 250rwkw give/take.
Cheap and nasty upgrade either way. Guess thats gonna happen more and more as GTR's come down in price.
There isn't anymore power to be made upping the boost beyond 1.1bar. The compressor is out of its efficiency zone after 16psi.. The extra boost and associated wheel speed doesn't make anymore flow.....just heat and the extra wheel speed is what takes your reliability away. At 120,000rpm the torque transfer from the ceramic turbine to the compressor becomes enough to break the ceramic/shaft fusion.
Matt
Both turbos are outputting to all 6 cylinders, because the inlet plenum spans all 6 inlet ports. They are each driven by 3 cylinders, which makes it easier to spool up to their maximum boost.
^ N1's are not ceramic :down:
The N1's will make 280-300rwkw, more if they are the larger version (they are not being discussed here though).
You need a ECU (Eg. PowerFC) to make use of this however.
yep ^^^ I made 285KW on my GTR last week, steel wheels and power fc 18psi 600 tomei on a mainline
and last night i tuned a mates car and made 300.2kw on 19psi steel wheels power fc and poncams stock injectors on a mainline
  • 4 weeks later...
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
