Hi guys!!
My GT-R is idling at 1050 rpm. Already cleaned the AAC valve before, butterflies were also checked... the car runs fine though. It's just the idle that keeps me wondering.
So GT-R gurus, is it just fine or there is something wrong w/ it? :/
Thanks in advance guys!
Edited by GodziRRa
https://www.sau.com.au/forums/topic/338405-gt-r-idle/
My mate has a bit of poly pipe made up with a compressor attachment and hooks it up befor the intercooler and pushes compressed air into the plenum via the intercooler.
start psi low and move it up to around 20 psi you will find any leaks at all if they are there.Keep a spray bottle with water handy and a peice of hollow pipe to listen threw :).
motor off of coarse.
https://www.sau.com.au/forums/topic/338405-gt-r-idle/#findComment-5470768
start psi low and move it up to around 20 psi you will find any leaks at all if they are there.Keep a spray bottle with water handy and a peice of hollow pipe to listen threw ;) .
Sounds like a lot of work. :D
https://www.sau.com.au/forums/topic/338405-gt-r-idle/#findComment-5473004
The ECU needs to be put into base-idle mode or else when you adjust that screw the ECU will just compensate.
Moo - is that info from the shop manual? My memory is that you unplug the electric connector to the AAC to stop the compensation, then adjust the idle to where you want it, then reconnect.
https://www.sau.com.au/forums/topic/338405-gt-r-idle/#findComment-5475677
another cheating way of adjusting idle is to have car warmed up, then watch AAC on consult and turn idle screw until its around 20-25. so depending if the AAC starts at ~20 (then u turn it until AAC starts to go up, then stop) or if it starts high (e.g. 40+) then you're turning it so AAC goes down until it stops going down. but this is when the car is running normally and just having minor issues, if there is something else causing high idle then this might not work.
e.g. i used to have warm start stalls due to AAC being too high (40-50) as idle was set too low and not having enough room to catch falling idle.
https://www.sau.com.au/forums/topic/338405-gt-r-idle/#findComment-5476146
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
