just got a text from a mate that his car has been pinched from the enfield area
number plates are S942 AAM and i'm assuming it's been reported
it's a white series 2 dayz, distinguishable features being the wheels, eyelids and dolphin grill
https://www.sau.com.au/forums/topic/338549-another-stagea-stolen/
  • Replies 51
Sorry to hear mate, hope they get it back all in one piece and they catch the dude with a sh*t load of stolen gear in it and he goes away for along time! Getting sick of this, makes me wanna not own a nice car!
alarm and insurance?
+1
certainly sad to see/hear of another import being stolen....assuming he had a alarm then thats just bad luck but if he didnt have one then its more so his fault for not having one.....i know i am being a bit harsh here but with all the cars being stolen lately you would be stupid not to have some sort of security....even an immobiliser...
hope you guys find the car in one piece and not burnt out somewhere....goodluck guys will certainly keep an eye out for this one
Sucks to hear another ones been stolen. Clublock em up!
Hoping it is the same tools that stole rodneys, that way they'll be driving it around and get spotted and hopfully caught.
Hope its found and in good nick. Will keep an eye out for it..
Yeah, time to ensure you've got adequate security. When I heard Rodders stag got nicked, I figured an immobiliser, hidden kill switch and club lock just wouldn't do the job no more ... so the stag is now kitted out with a full alarm install and gps tracker (and still using the club lock and hidden kill switch).
And I'm never usually very far from the stag, so lets see the mongrels come for mine :)
Sorry to hear about the theft. Hope you're lucky and you get it back in original/reasonable condition.
Yes alarm
Yes insurance
Without naming brands... If u have got min of rolling code and 3 point... Ur in playing with fire!
I know what alarm he had. And feck me its not kool!!
Will keep my eyes out for it :) Bloody hell.
Yes alarm
Yes insurance
what do you mean min rolling code and 3 point?
what would you recommend for an alarm/imobiliser?
Ima bit of a novice, but my understanding is that a rolling code is essentially a system that uses an algorithm that is unique to your alarm/immobiliser - so every few minutes the code that your remote sends to the car to disable it actually changes, based on this algorithm. This means that a near by crim cant just 'listen' for the unlock sequence and then replay it at a later date when you're not around; because the sequence will have changed and will never be useful again. Its the same way the 'RSA Tokens' that banks use, and some large companies use for Remote IT logins etc.
Im pretty sure Autowatch complies with both 3 points of immobilisation and rolling codes.
Oh man - not another one, see this car around a fair bit (before it was stolen), will definately keep an eye out. Making me nervous about mine now - but touch wood they'd have a hard job getting to it!
Thanks everyone. The car was stolen around 9.30pm which is weird because i know if i was going to steal a car i wouldnt do it at this time but they def must of know what they were doing, Were lucky we have insurance and that we have a second car to get around in. Just so frustrating that there were personal thing in the car. They are targeting the area an RX7 was stolen a few streets away monday night which i just found out and another friend had some silvia parts stolen from his house so if u live around the enfield area be careful, Dont want to see this happen to another person. Guess we just have to play the waiting game now ;) Thanks to all the guys that have msg'd josh i know thats really helped
You could see just how pro they are, if you start taking away the ECU from the car at night. Or option 2 which is to setup a sniper position 300-500m away, i mean hey if the Washington Sniper could do it.....
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
