  • Replies 108
I'm gonna do some really early runs then chill till the eliminations
It'll be you & me, & damn near EVERYONE else following the same plan mate.
F@$&!#G weather :P It just had to pick the one day a yr that the Nats are on to hit mid 40's!
Yeah it sucks but what can you do?!
This arvo my car started doing something unusual - I had my exhaust fixed this morning cos I bent it a bit on a kerb (long story) and now it seems to get a real shudder around 4,500rpm in almost every gear .... either that or my flywheel is slipping (is that even possible?) .... either way I don't like it. Will see how it goes tomorrow. Other than that the power is excellent currently so I am fairly happy.
I just put 4 litres of tolulene in my tank with 20 litres of fuel .... that'll hopefully prevent any pinging in the hot weather :P
Looking at tonights BOM update there's a tiny chance things will cool down a tad later in the evening...... It does give a Min on Sat & Sun of low/mid 20's though.
Saturday : Very hot with freshening northeast to northwest winds, ahead of a
*moderate to fresh west to southwest wind change during the afternoon. Becoming
milder in the evening*. A possible thundery shower about the northern ranges with
the change.
Adelaide City Min 24 Max 43
Elizabeth Min 23 Max 43
Yep. Too many 180Bs, magnas & crappy chookcookers.
We should just have our own one next year - still meet with the big group,
but then go else where so we dont get stuck behind 16 y/olds in mummys magna.
SAPOL & Regency pressure has certainly pushed a number of the "nicer/serious" cars into hiding. I for one will not go near a major cruise these days! It really is sad :) What ever happened to police discretion? We can thank the idiots who act before they nail the throttle/do burnouts & so on for the extreme scrutiny. I'm not saying don't have a bit of fun on the road but think before you act!
Rant over.
Thanks John :)
Like I said in one of the other threads, I'm happy considering the heat, running with a boost leak (could feel the car down on power on the 12.8) & over 12mths since I'd last hit the strip. I feel a bit bummed at not getting the full potential out of the car, but there's always next time.
yeah i was stuck behind a couple geminis and a pulsar everywhere, that made the cruise even worse
also a few people put there foot down (a bit)as they were leaving the carpark, and the cop was taking down there rego's
Hey all Was unable to get to the Nationals it was just one thing after another and in the heat travelling from the sticks was to much. Was the cruise like last years ? I heard it was a rotor nationals. GTR's was there any at all ? and Munro what happened? So many questions
Lets make the dates for the Nationals in Autum, with a pre arranged weather of around 23c and small breez. Plenty of half naked women serving the drivers with drinks and food, Great music and some interstate door slamers and top fuelers to spice it up that little more.
Anyway it was just an idea.
  • 3 weeks later...
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
