Guys
Where to you take your 35 for one of these packages with Cobb AP in Melbourne? Has anyone done any of the mentioned packages or similar?
I'm still researching which package to go for but given Willall being local has its advantages - or may be not! I'm looking for a street setup with the occasional track days.
I've had SS for 1 year now and it's time to play :)
Thanks for any guidance - Vu
https://www.sau.com.au/forums/topic/338592-capable-workshop-in-melbourne/
Racepace I hear can do Cobb maps for the R35. They use Akropovic exhausts and I think have done a few other things for cutomers e.g. brakes. Ben is a GTR tuner and I hear is a bit of an expert at working and tuning the older GTR models.
Can I get a discount Ben for plugging? :)
^ if you catch him there, he's not there as much these days
I'd give Trent @ Status tuning a call (now known as chequered tuning www.chequeredtuning.com) - all Trent does now is tune, and he is very knowledgeable across a wide range of ECU's.
I'm sure he would look after you very well for whatever your plans are :)
^ Ye but trent doesnt have Cobb far as i know which is what the OP is specifically asking about.
RE customs have the software. I believe there are a few others around, no doubt Snowman will post up as he should know :)
^ Ye but trent doesnt have Cobb far as i know which is what the OP is specifically asking about. RE customs have the software. I believe there are a few others around, no doubt Snowman will post up as he should know :P
Thanks guys, I'll give those shop a call.
Ray at RE Customs did some work on my EVO9 previously and were pretty good.
Vu
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
