Firstly, hello Melbournites, my name is Adam and i've moved here from Perth last week. i have a little problem, my r33 is a sick backfiring fuel guzzling got-no-power farting mess at the moment.
o2 sensor has been changed, wiring has been checked, new plugs etc etc... 3 different places in perth have no idea what's wrong since it's a sporadic problem (ALWAYS brought on by driving on boost for a few minutes)
i'm living in heidelberg.
anyone recommend any shops that would be good for this sort of thing? i've found a few places that look likely in the yellow pages but they are all miles away.
thanks heaps in advance guys
my fuel bill and my sanity depend on you!!
Adam 0411802806
https://www.sau.com.au/forums/topic/33863-help/
M.I. (Mirror Image) Automotive in Bulleen always serviced my R33, I would highly recommend them. You could almost walk there from Heidelberg. They'll also chuck the car on the dyno for free after the service to see what it's making, tuning is obviously extra.
M.I. Automotive
211 Bulleen Rd.
Bulleen
9850 5311
https://www.sau.com.au/forums/topic/33863-help/#findComment-679424
Yep have a SAFC and the same problem happens when it's on or when it's in "omit" mode, so we've ruled that out. fuel pressures are ok, seems to be something electircal coz it cuts out for a few seconds on the freeway then comes back to life. still makes good power on the dyno when it's behaving, which is becoming less and less frequently. it's an intermittent problem, making it even more annoying.
*sigh*
anyways, wish me luck, and thanks for the help guys. and say hi if you see a WA-plated silver r33 around!
https://www.sau.com.au/forums/topic/33863-help/#findComment-680543
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
