  • Replies 71
If you only find deer, you're doing good! Lol. Of a night it can be a terribly dangerous road!
My missus lives right near it was like "there's no deer in there" until we went past 20 of them... Lol, I've come across lots of animals in there, which is expected being a national park...
Once went through there at night and came across a couple of *deer* standing in the middle of the road. :banana: Was foggy too, crazy stuff.
RNP definitely requires keeping eyes peeled and wits about, even more than usual.
... thanks gents for the headsup ... fingers crossed im not working ... cheers malcolm :D
i might be up for this, looking for an excuse to get out of something else :bunny:
^^^ You pinched my excuse :P
Have to see what God_speed is doing tho' because he had an accident last night at about 6 o'clock.
Got rear-ended - by a deer :)
...a Cayenne deer :laugh:
*Correction:- Cayman deer!
...a Cayenne deer :)
I hope it was in the daily not the R!!
Will txt him in the morning to see if he is ok..
Thanks David, you're a gentleman.
From what I can gather, it was like...
Three green bottles hanging on the wall: three green bottles hanging on the wall: and if one green bottle should accidentally fall; there'll be two green bottles hanging on the wall!
Well the Porsche driver ran up the third green bottle, and Matt's GT-R was the last green bottle at the front of a queue. One of the green bottles was a Beemer too I think. Damage to the GT-R is repairable. #2 green bottle hit him mainly in the left rear part of the bar + collecting the Fujitsubo tip > pushed the bar out to the right a little. The bar is repairable too; but if a new one can be sourced and keep the current one, that'd be better still. Dunno about the reo/beaver panel.
Yeah it was a Porsche Gayman actually.
Fortunately it was more like a love-tap to the GTR by the time the impact reached my car. I have no idea what he was doing as he hit the VT commodore with a fair bit of force. 6 o clock Thursday arvo, peak hour, stop start traffic. At least I'd left decent space to the car in front of me so the buck stopped with me so to speak.
Second time I had taken the car out in about 3 weeks.
I will join for a drive and lunch.
I endorse the rules as spelled out earlier in this post. If you can't control or behave yourself please stay at home. You will only give all of us a bad rep.
Please help to make this an enjoyable day and not one we would rather forget..
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
