I would like some help with the options I'm looking at.
My 32 gts is street driven, but needs to be strong and reliable for light competion use in hill climbs, super sprints and tarmac rallies events.
With it's original RB20, a few bolt on support systems and a 15psi via an old HKS turbo it was making a healthy 200rwkw. However it has now lost a significant amount of compression and needs replacing or a rebuild.
Option A: rebuild another RB20 with GTR crank, rods & forged toyota pistons giving me @ 2.4 litres
Option B: fit an RB25
Option C: fit an RB26
I want at least the same level of power as before with increased torque in the lower revs.
I'm not sure how much money needs to be spent on top of the first two options in order to achieve the same performance and reliability level of an RB26.
But Option B & C will not be rebuilt after purchasing due to the initial outlay.
Anyone done anything like this and whats involved that i may not know about??
https://www.sau.com.au/forums/topic/33883-best-option-rb24-25-0r-26/
  • Replies 43
You need to be mindful of the allowable modifications in each event.
I would expect the best bang for your buck will be the RB25DET upgrade. But you'll need the ECU as well. More low-down torque from the increased capacity, just as much up top.
The RB24, as well as the cost of the build, will require a re-program of the R32 ECU, or an aftermarket job.
The RB26DETT is just too expensive for the purpose (more serious motorsport might justify it)
hi drifto. The RB24 sounds cool, but i agree with the best bang for your buck being an rb25. This motor will do ~200rwkw in its sleep with the stock turbo and an aft. ECU, plus have good torque. You may even be able to use your old HKS turbo for more power. What turbo do you have?
I've done a bit of investigating for an RB24 (or even 22) conversion, and you're looking at big $. Sydneykid & Rob helped me out with a lot of info. I would point you to the thread, but it's disappeared in the lost month of November :O maybe tis could be the start of the new thread. I'm looking for the same as you pretty much. A stronger, more reliable engine. I've been looking at a lot of the Tomei internals...but there is still much research to be done. email me [email protected] :( we could share info as we come across it. where do you live?
A properly done RB24 conversion is going to cost a lot more than 4.5K. 4.5K will buy you the pistons and rods...then there's the crank (RB26 - $$$), valvetrain, boring of the block, boring the head to match, bearings, machining of the block to fit the oversized crank, ECU...
I'm putting together some costs soon to ease my own curiousity (it won't be for a few weeks though - moving south :(). I'd be more than happy to share my results with anyone who's interested :)
but agreed...the rb25 conversion is definitely the cheaper option :O
Id say it really depends on how much money you have and how far you are willing to go.
Things i would be considering when looking at which avenue to take is:
- will you be happy running the std RB20 5 spd behind whatever you build
- are you going to upgrade the turbo
I wouldnt consider the Rb25 myslef, unless of course you get a good price on a perfectly running example.
The price of getting an unknown quantity in the shape of an RB25 which is still going to cost you upwards of $1500, if rather be throwing that money at an RB24. (Unless you think you will approach a power level where the smaller RB20 valves will be hurting power)
Depending on what you are doing with your current turbo, id say rebuild the RB20 -> RB22 with 82mm pistons, and some cams, (GTR valvetrain perhaps) OR build up a RB30DET.
But if you can scratch together the GTR crank and rods for a reasonable price, then i would be taking that path. :O
Hi guys, this is some of the stuff I posted in that thread........
An RB20 is 78 mm bore and RB25, RB26 and RB30 are all 86 mm bore. You can't bore a RB20 block 8 mm oversize. So you can't use RB25, RB26 or RB30 pistons in an RB20. About 82 mm is about as big as you can go (4AGZE pistons are a common choice).
An RB20 has a 69.7 mm stroke and RB25 is 71 mm, RB26 is 73.7 mm and RB30 is 85 mm. You can use an RB25 and RB26 crank and rods in an RB20 block. RB30 won't fit. RB25 fits in no mods RB26 needs a little work on the block to clear the crank counterweights and rod bolts.
Using an RB26 crank and rods and 4AGZE pistons gives around 2340 cc's.
If you add it all up I bet an RB25DET will be cheaper and at 2,476 cc's bigger as well.
If you want to see how this sort of rebuild goes, check out JOnJOn's posts as he is doing exactly that.
Good comments Guys, Cheers
I'm waiting for a qoute from my engine builder who just happened to have a GTR crank & set of rods. He also suggested the toyota forged pistons which are reasonably priced compared to custom forgys or aftermarket jappo ones.
I will post this option as it comes together.
Meanwhile my engine wont even start, mechanic thinks now that the comp ratio is so low in some of the cylinders that it can't kick.
It had been running pretty well before so some damage may have been done when the original leaky injector prob caused a severe flooding of the engine.
He has got it to start but only by taking all the full pressure out of the rail to about 12psi, as soon as the fuel press is normal about 35psi it floods and stalls??????
So now i'v gotta put a new engine in. Apparently!!!
$700 for 2nd hand rb20 minus turbs, $600 for install labour
Should i just go an rb25 now instead?
I already have APEX piggy back AFC & ITC
GTR fuel pump & adjustable fuel reg
A steel wheel HKS turbo of uknown specs (200rwkw 15psi RB20)
Checked out those other posts, thanks Skyline Boy!
Seems my RB24 will be limited straight away by the stock head unless i'm gonna port, valve & cam it.
I'v heard the same regarding the 25 head tho ?
Would a 25 conversion require changes to the gearbox, clutch or other things apart from the hassle of having the new dispacement certified and engineered.
If i throw another rb20 in now then build my original one I can put it back in with original engine numbers before rego is up and no one the wiser about it 2.4 capacity.
The questions are, what is the standard head capable of flowing as i'm not after top end peak power but a torquey power curve that will stay stong till about 7500 rpm
Would my existing HKS turbo be too small for the 2.4 capacity? either way it has to be better than a stock rb25 ceramic wheel.
If we can keep this thread going for a while i'll post results and experiencres as it happens.
Should be good info for a lot of skyline owners looking at rebuild options.
I don't like the idea of a rb30 for a number of reason,
they came in commodores
they are single cam, unless you spend lots of money purchasing and fitting a 25 or 26 head
i'll definatley need a new turbo for 3 litre capacity
rego, insurance, resale
It also changes the cars character too much!
But thanks anyway for your option
the rb 30 is a nissan engine.
the dohc head costs 750 comes with inlet manifold, fuel rail etc.
the r32 rb25de head is a straight bolt on to the rb30e bottom end - no modification.
your turbo is fine (im using the rb20 one which is high flowed till i can afford the biggun)
rego, insurance, dont tell em
resale - prolly get more buyers :)
changing cars character - what, u like a lotta lag? stalling it to 3500 to take off at a decent speed?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
