I've got a spoiler for sale and I need to get a quote for a guy that's interstate. I've never sent anything that big interstate before, so I don't know which courier to go with.
So does anyone have any suggestions for a cheap and reliable courier company? :(
Thanks!
https://www.sau.com.au/forums/topic/339110-anyone-know-any-good-couriers/
Thanks!
transdirect.com.au
used them heaps of times, even sent an engine on a pallet to Darwin.
Yes i agree i hate metrans too lol
Im a sales rep for a courier company. Jules who do you use?
Where to start...
Couriers Please for non-urgent local deliveries. Xpress, MTX & Jet for same-day/urgent local deliveries.
TNT for same-day interstate, overnight, country VIC and small interstate road packages up to ~50Kg depending on where they're going. Niche Transport, WA Freightlines and NQX for larger road freight consignments 50Kg - 10tonne again depending on where they're going.
TNT, DHL & various freight forwarders for overseas deliveries.
  • 5 months later...
Hey guys,
Can anyone of you who used e-go answer this for me? :D
I've gotta post a front bar to NSW and we are gonna do depot to depot and I'm just wondering, if I drop the bar off t the depot, do I still need to pay and book online?
I wanted to call them but can't find their phone number.
And what happens if I accidentally enter the incorrect weight or size of it, by a kg or 10cm or something? Lol
Also, is about $120 to post a bumper sound fair?
Cheers!!
charles everything is booked online, just have to take proper measurements and weight etc
What happens if the measurements are a little bit off?
And I've been looking around on the net, I've seen a fair few negative feedbacks about them... So I'm a little iffy about using them lol
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
