Guys,
I've had my line for a few months now, loving every minute of it.
But something has been baffling me since word go.
on the back shelf there is a small (maybe the size of a 1ltr ice cream tub but flatter
) box with a few leds and whirring fans, when i asked the previous owner what this was (just after i had bought it) he shugged and said "a dehumidifier" i quizzed further and i was told that it came stock with his import.
No problems there, but the thing that is baffling me is none of my mates lines have one, or didnt when they bought them. Have i ended up with the ultimate rice accessorie option (pointless and electronic) or would some one have fitted it after purchase?
Messiah
https://www.sau.com.au/forums/topic/33955-dehumidifier/
Messiah
My Series II has one also and is constantly on - can't seem to find an on/off switch. My Mazda 626 Coupe import had one also (way back in 1990) that some kids stole out of it thinking it was a sub or something.
They were called air purifiers from what I remember - was your car a smokers' car in Japan as they seem popular with smokers cars.
Don't seem to do much though apart from use up power and take up space.
Cheers, Al
https://www.sau.com.au/forums/topic/33955-dehumidifier/#findComment-681741
PVA,
Pretty sure yeah, it sits well clear of the rear window on the back parcel shelf. not rigged into anything mechanical in the space next to the battery, just power.
Sounds to me like it is a dehumidifier/air filter of some type, heh now the curiosity is why i have one but most dont. Makes me feel all special.
https://www.sau.com.au/forums/topic/33955-dehumidifier/#findComment-682128
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
