  • Replies 52
Posted Images
this is how they looked initially without tyre or set down on suspension.. we thought theyd pull in .. they barely pulled in half an inch though.
not giving up yet though.. ill attempt again after coil overs. definately +30
http://i288.photobucket.com/albums/ll166/K...ag/IMG_0212.jpg
Edited by PetroDola
Mate that is 100% fine! im not sure why you are concerned! thats with the car on a hoist! Mine looks exactly the same.
Just put some tyres on and set this thing on the ground....
called another mate.. who said they probably lied about testing the tyre because if its new rims you fit the tyre you pay for the tyre..(as i only saw the rim and not the tyre on the rim.. they called me and said no go) and that he works at another beaurepairs so they always test the rims prior if its them selling the rims. .. he is going to use an old 19" tyre to test fit it tomorrow and actually drop it on its weight. then play with some camber settings. ... could be on a winner! :)
Sorry to comment after the fact but it seems you were poorly advised on the basis of people who are prepared to run excessive negative camber and put "stretched" tyres on. I don't usually comment on these wheel fitment matters because I am probably considered old fashioned or maybe just old! I hate stretched tyres. Even 245 on a 9.5 rim seems too small for me. I have 235/45 on my 8in rims and when I get my 33 GTR rims (9in) I will be looking for 255 or 265 - whatever is most price effective.
I'm the same, I hate stretched tyres too. I've got 245s on my 8" wheels (but that's on a C34). In my opinion it looks tougher, and it helps that there's less chance of rubbing the wheel on a gutter or something too.
What suspension do M35's have on them? If it's double-wishbones f+r, then I'm *pretty sure* that as soon as you put some weight on them the suspension should tuck up and in by way of how the geometry works, right???
+1 for it's gonna be fine, that pic is hardly any poke at all it will tuck for sure, where is mike and pics of his vskf test fits I know it's a c34 but it would give you an idea.
Edited by horrace
double wishbones heh... no idea..can anyone confirm? pretty sure they do looking at the back previously.
sounds fairly logical though :)
Edited by PetroDola
i have a few things i would rather not say about beaurepairs (that is where you car went wasnt it??).. but thats just from a few of my experiences with them... what the hell i will say one thing.. i drop my car off for a wheel alignment (17" rim corolla, no camber bolts perfect fit without guard rolling for my simmons) they ring me saying the camber is all out of whack i say how can it be?? i go down there and my front left looks like this \\ and the right like this \\ im like wtf did you do?? they said you gotta buy a set of camber bolts to straighten it up!! i said show me where, i looked and told them to get the bolts they had aready installed and never touch my car again,,, rip off F%%ks
trying to sell me a set after installing them already at wrong settings to make my car look crazy with positive on one side and neg on the other...
Anyway back on topic.. I reckon it would fit only because with my car lowered even though i only have standard 17's there is bucketloads of width available, but yes when you raise it this disapears,
and yes im pretty sure they have double wishbone F+R i was looking when doing my brake discs, Very GRAND TOURING!!
MAKE EM FIT i want 9.5 wide too your my guinea pig!!
hehe im going to make em fit.. the thing is i shouldve gone to the dudes i knew rather than the dudes who were closest as they were willing to do what i requested and took my word that theyll fit. took it in this morning to my mates who test fitted a spare 19x40 and it fit awesome.. front gaurd was a bit off .. and rear was still a bit off but i reckon with coil overs or new springs to match my new front dampers and new rear springs i reckon i could get it to tuck under quite nicely without a huge amount of camber. photos to come.
http://i288.photobucket.com/albums/ll166/K...n/Photo0008.jpg
http://i288.photobucket.com/albums/ll166/K...n/Photo0007.jpg
http://i288.photobucket.com/albums/ll166/K...n/Photo0009.jpg
heres how it looks on the stock suspension.. if i can get an inch (someone said 25mm?) extra clearance with the coilovers or lowered springs i should be good!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
