I figured since I have been working on all variants of these cars I may as well buy one.
A Qld club member had this one up for sale about jan feb this year. by the time I had found the advert it had sold to someone else in northern brisbane. conditions changed for the new owner and I got a phone call. went out had a look agreed to purchase it as was.
the car is a HNR32 - DEC 89 build wiht Grey interior and AH3 (red) paint and 5sp manual
paint is well beyond repair and most of the interior panels need repair or replacing.
the RB20DT engine is also dead. gearbox unsure of condition so it will also be pulled down and inspected with broken/worns items tossed for new ones.
apart from a bit of rust in spots the body is straight as can be with a pin dent here and there.
the goal is to restore it with a few minor changes.
engine at this point will be a RB25/30 with a PFC on it.
Front end - GTR. I am doing this simply because somewhere over the last 21 yrs someone cut the front mount hole out of the drivers front area. so I may as well use it.
brakes - R34 Brembo front and rear
Interior - stock GTS4 - the seats are in good nick and after being given a few 32 GTRs for a week at a time I'm not really a fan of the seats for daily use.
Wheels - 17" of some OEM variety. would like to do the stock 16"s but clearance on the brakes kills that idea.
Things to replace/repair: (I'll provide part numbers as I do them.)
ALL rubbers
both door sills (inner/outer)
repair front frame rails - due to someone lifting the car wrong..
inner front plastic guards - both sides.
rear parcel tray (this will be rebuilt)
seat belts - all 4
ALL interior covered trim - inc side window trims
heater vents - dash.
radio panel
rear console
panel under steering wheel. - someone bolted a turbo timer to it and made a horrible mess..
shifter cover
rubber shift boot that isolates the body from the inside cabin
A/C controller - mine does not light up - works fine.
Carpet - if I can still buy it.
instrument cluster panel - GTR version with clock.
every missing screw inside.
plastic screws in the sill panels
Sill panels with skyline logo
Floor mats - OEM.
things to tidy up / paint/clean
entire car - factory color with new decals and emblems
engine bay - factory flat red
black stone coat underneath/inside rear wheels
engine in factory black colors
small parts.
every clamp on the car - new if I can still get them.
thats the start of it. I'm bagging and tagging bits now so I know where it came from.
pics to follow.
update 09/01/12 parts list added. more to follow.
76450-01U00 - Sill inner - right $190
76451-01U00 - Sill Inner - Left $190
76412-04U36 - Sill outer RH $275.
76413-04U36 - Sill outer LH $275
- Inner Panels behind headlights
64130-05U35 Hoodledge Lower RT
64131-05U35 Hoodledge Lower LT
- both sides.
63842-05U80 - guard protector - RT $160 (GTR) (Note GTST is narrow on the top of the wheel arch these are not.)
63843-05U80 - guard protector - LT $160 (GTR)
I am using a mix of GTST and GTR to make the lower brake ducts work correctly.
75890-05U20 -under tray $170 (this is a 4wd undertray. 2wd is DIFFERENT!)
62022-05U27 Front Bumper Cover (GTR) $578
78120-04U00 - Base Filler lid $40
78134-04U00 - corner rear fender RH $45
78112-04U30 - fender rear RH $850
79400-04U30 - Rear parcel shelf - main steel panel $450
73112-04U35 - Roof Panel - Sunroof version $758
91210-04U11 - Sun Roof Glass (S2 - S1 out of production) $1300.
62550-01U30 - GTS4/GTST- Bonnet catch support
62550-08U31 - GTR ( I am using this one due to the front swap.)
https://www.sau.com.au/forums/topic/339677-r32-gts4-restorationrebuild/
ok this is how I bought the car:
looks ok side on :)
I'm not much on the wheels. (they are 17" and for sale with almost new rubber attached) to me they do not suit the car.
for those expecting a quick build - not quite. whilst I may own a business that works on cars, the business does not own the car - I do.
as such I'm saving up for bigger items and once the funds are available - buying them.
now for the fun stuff !!
the 'burn' markon the bonnet is from a battery fire. I have a harness to rebuild once the engine comes out. the car still powers up and everything runs so from the outside it can't be that bad. I'm going to tap a few other nissan vehicles for parts.
A D22 Navara will donate a fused battery terminal. that way I can do away with the fusible links that have decayed over the past 21 yrs.
(toyota alaso use them for reference.)
the engine is a mess from the outside. the cooler piping I think is way too long and I'm not a fan of BOVs that vent externally. the ones on my subaru (two as its twin turbo.) are quite loud inside the car and do not scream look at me when I back off. the cooler and piping are up for grabs. I'm putting stock 32 GTR items back in that spot with the piping going left to right. the intake plenum I will try for a foward facing item.
as I said the body has a few spots in it that need attention. I spent the last few days after hours tearing the car down and accessing/locating most of them. the inside sills seem to be a common place for rust on this chassis. I have noticed it on several 32 GTRs where they have crushed the sills by raising the car incorrectly. if you have crushed sills lean the carpet back forward of the boot release and look. there is a fair chance that its rusted. Why? The seam on the bottom is crushed and allows water to pool. that is what happened to this car. its $1k in panels to fix it and I have already ordered them.
the sunroof shot is surface rust. talking to the panel beater he's going to cut that bit out (its a 6-8" section.) , remake it and brass it back into place. I was prepared to buy a roof panel but was told not to.
I'm doing the paint stripping myself back to bare metal (cost saving as I can do that part of things ) then covering it in etch primer once its stripped off. any outside or visible panel gets this treatment. I expect to get my share of chemical burns :D
the seats in general (cloth/fabric based stuff) are not that bad. the only way these will get done is if I cannot find the same (or close) material to fix the doors/rear panels.
this area is pretty much a write off. it seems most of these I have seen over the years have been cracked at the top or base. I have parts prices for this and the only thing I'm uncertain on is the color of the panels. that radio panel as you can tell is black. most of the GTR ones I have found are grey. I would like a new black one IF I/nissan can find it. the dash vents on first view appear ok - they are not. new ones of these are going in. the lower drivers panel (one under the wheel) is getting the flick for a new (or near new) one.
more to come.
Edited by Chris Rogers
A very thorough plan and build, I will be following the "red twin" of my differents themed GTS4 build.
yep its going to take a while. mate of mine wants it done yesterday so he can go for a run in it :D (waves- you know who you are.)
put some shots of yours up.
I'll start by doing the interior panels as they are cheapish:
ordered the two rear window panels today $160 ea.
next to order( and once I save money to pay for them) - the dash/centre console panels.
piccies (with Part numbers) once they land.
ok just ordered NEW inner GTR guardliners for it. these may need a trim once I get them here.
reason for buying them: oil coolers.
I'm going to mount one in either side out of view but in the airstream and that is the only way I can see to do it neatly.
$130 each and available ex MLB.
yep fuuny thing is I expected a hard time buying things for this car. 99% of it is local and the 1% thats not is still in production ex japan. to me thats not too shabby for a 16-21 yr old car.
couple of stripped shots :
rust is actually worse with the car assembled. most of the underside is fairly clean
front on:
a few rusted and snapped 10mm bolts. at least I can get at them from the back. wiper assy needs doing as well once I cut 6 bolts loose.
rear shots. you cannot really see the 2" push where it has hit something. rest is fine.
I'm still pulling it down and hopefully in the next week or two I'll have it back to a shell so I can start prep work.
spent today pulling out the ABS unit, brake booster,radiator and associated harnesses.
also put EVERYTHING I need to buy for it on a BIG list and made a book for it with images. this will make it easier for me to cross things off as I buy them.
engine and box come out next weekend. then the fun begins - CLEANING!
daniel,
ta!
ok this is a set of PDFs I knocked up. these are for the door seals and the rear side panels. when looking for part numbers I found these were a bit hard to find so for everyone elses sake they are posted here.
R32_doorseals_image.pdf
R32_doorseals_parts_list.pdf
that covers the entire side. so door rubber trims,body rubber trims, new 'skyline' sill panels,clips (which always seem to be MISSING!) side window trim, lower side trim. these are done fro trim code G in my case. the rubber items ARE NOT cheap. the window trim is ($160 a side.)
I'll add a few more PDFs later. I have a book (as mentioned earlier) now with every trim part I need to replace on this car so my life will be a bit easier when it comes to buying things.
I did a parts blowup of a R32 GTR N1 (yes I have done one - I just didnt realise it!) front end and thats where I'm starting with my body parts.
next photos will be of new parts. (and a empty wallet. :D )
oversea for big bits - local for smaller ones - local is metro nissan in windsor O/S - company I do a LOT fo business with in Nagoya.
FAST - older version floating around on the net. as for the shop current FAST version - I know someone.
this keeps getting better :)
the car has a FULL set of tein coilovers under it!!
unsure of condition but they are definitely TEIN!
I am crawling around under it again removing things.
That's a nice surprise. Good to see how "stuck into" this project you are.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
