  • Replies 172
no sorry as this is a manual it has the three guages and the single cd player
hi,
would you be willing to sell just the metal mounting bracket for the stereo?? mines all cut up.
cheers Ray
hi,
cheers Ray
i think i have already sold it i will look to see if i still have it
hey i need the plastic 'recline' handle off the side of the drivers seat (mine has just vanished). are your seats black with blue inlay and look like R34GTT seats? if yes then how much just for the handle if you'll part it
i would prefer not to take it off so i can sell the seats whole
sorry
Have you still got the plastic handle in the boot for folding down the rear seats. I'm after the driver side one.
i am not 100% sure i will check over the week end and let you no
Hey Ryan,
I'm after the interior A/C control unit please?
Edit: Loom/harness too maybe... I'm moving away from my touch screen / tv / satnav unit.
  • 1 month later...
  • 1 month later...
