Genisis: i drove home from a party in manly on sat night at 3am and was up for work at 8am on sunday! Dont be soft...
haha... ok... most probs i will be joining you guys on thursday.
and its 'Genesis', NOT 'Genisis' ... the latter sounded kinda perverted :D
  • Replies 117
Ok my apoligies to everyone about my first request being for a cruise, if it's ok i'd like to come out to meet and greet, and see what you are all driving etc. I'd hardly expect you to invite me on a cruise the first time I meet you. I've read some of the posts on where you've been meeting on thursday night before but I just can't seem to find any of you.
Charly, have you not read the initiation process to join the l337 //GC Crew?
As for team //GC... There is quite an initiation process. You must first propel your skyline down the 1/4 mile in under 5 secs. Then provide all current members with $500ea. Next comes the good old 200mph roof ride. And finally, the Evil Kinevel Skyline Bus Jump...
:headbang:
:jump:
See youz all there!
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
