unless your after something in particular you dont really need to ask for anything other than a tune as they should know what they are doing. should be done after doing mods and it should make use of them additions to give you some gains whist still being safe on the engine.
Hey guys just wondering what you guys ask for and expect from the tuner when you take the car in to get tuned.
It also depends on what u want changed on the car aswell ! Eg You might want ur turbo to come on boost a little early then what it's doing at present or u might want better fuel economy . You gotta work out what u & the tuner can do together , a little bit of team work so to say !
So every time you get a mod you gotta get a tune?? I haven't had a tune since I got my 32 the only mods I have is cooler, bov spitfire coilpacks? Do I need a remap?
you dont need a re-map from those mods as they are just supporting mods and wont really affect how the ecu works. things like air flow sensor, injectors, higher boost from turbo, adjustments to fuel pressure etc so its worthwhile doing a few mods at once to cut down on visits to the tuner
you can probably answer your own question there.. are u asking because your taking your car in for a tune? if so, what are you getting it tuned for? does it not run nicely? have you made some modifications and now your chasing more power? thats generally what a tune is for.
in terms of what you ask for, that really depends what you want and what the capabilities of your engine are. anyone tuning your vehicle should be discussing all the relevant details with you before they start playing with the car.
maybe elaborate on what your setup is, and why your thinking of getting a tune in the first place?
ah ok thanks mate this my first import um well need a tune soon once diff is fixed due running rough as. Cheers again
it may not be tune related, could be fuel or ignition dramas for example but if it hasnt been on the dyno since you bought it, then it would be a good idea to make sure the last owner didnt have it running on the edge
Don't expect a tune to magically fix existing problems, you should only be getting it tuned when it's running perfectly. I've bolded what the problem most likely is.
yeah a tune won't fix what is making the car run poorly. it will simply mask the problem. if the car is running rough then it means there is a mechanical/electrical issue causing it to run rough and you need to sort that out before getting it tuned.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
