hello, was doing some searching about exhaust manifolds on here, but got nothing i wanted to find.
my question is, im looking at replacing my original rb25det turbo manifold fomr the NEO engine,
since i want to keep original dump pipe etc, what manifold do i need??? my guess is low mount manifold, but will it all sit back the way it was????
im just looking at a bit better spool up and ive seen a couple of different manifolds which im interested in, just waiting to hear on the length of each cylinder pipe.
i will calculate what manifold is better for low down rpm.
so is the low manifold designed to keep stock stuff on???
i just dont want to sell my new downpipe to get one that fits the new manifold.
thanks
Jean
https://www.sau.com.au/forums/topic/340679-exhaust-manifolds/
i heard there is minimal to no gains to be made on the neo from aftermarket low mount manifold, if you was going highmount yes,
i have r34 gtt built motor, 3076, all supporting mods and stock manifold last dyno was 311rwkw with wheel spin (with amount of camber i have we couldnt eliminate the wheel spin) on 19psi
actually, just a quick question, this has been bugging me for a loong time.
the so called turbo manifolds and extractors, which would be more efficient at quick spooling????
the manifold or the extractor???
if you think of it theoretically, the spool time depends on how fast your exhaust gases can get to your turbo.
say the stock manifold is set up like this:
cylinder 1 is a 20cm pipe to turbo, cylinder 2 is a 6cm to turbo, cylinder 3 is also 6cm to turbo and cylinder 4 is 20cm to turbo.
that means the shortest exhaust gases will come from cylinder 2 and 3. to travel the 6cm, means short turbo spool or turbo lag.
while with a mandrel bent extractor, cylinder 1 will be 25cm, cylinder 2 is 15cm, cylinder 3 is 15cm and cylinder 4 is 25cm. it means it will be able to get the engine to run more freely, but it does not guarantee a faster travel of the gases to the turbo, so higher up you should see a bigger increase in engine power, 15-30hp on a basic extractor. but therefore a bit longer turbo lag from the longer gas flow. gas travels 6cm in the manifold and 15cm in the extractors.
while this is not the case for NA cars since they dont need to run a turbo, they would benefit from it alot better.
so is this really the case when buying extractors???
would the turbo lag be increased but the overall power gain in the higher rpm???
well extractors is anything non original manifold basically, it extracts your gases, tuned length, manifold is just the basic crap you get on your stock car, NA or turbo. well from my view at least.
but say you popped a t45 or t66 on there, a top mount, that should kick your lag in to well over 4k rpm.
You have one manifold - It's being forced out, not extracted.
There is a difference.
A stock RB25 manifold seems to be good for around 300rwkw.
I remember back when Joel (Cubes) and others were playing around with a 25/30, 300rwkw of flow seemed to be about the limit airflow wise with some gains had by changing.
So that said, anything 300rwkw or less - spend the money elsewhere.
That pretty much covers off 99/100 set-ups nicely. And the cost of a good manifold is basically a full car of pad/rotor/fluid/lines in terms of a brake upgrade... Something you will notice a lot more :worship:
There was a table of test results for manifolds kicking around. I think it was bench flowed results, it would be a bit dated now, but it was good because it had back to back tests in it.
The HKS cast low mount came out best overall, but I'm sure some of the well built ones like 6boost etc would be just as good these days [not sure if they were around when the tests were done?]
If you searched you could probably still find it, think it was on a UK site but may have been an NZ test?
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
