I know all of us are sick of the RTA but today I've just had enough of them.
Yesterday I called their "helpline" and was forced to wait for 10 minutes before I got to speak to a real person. I literally said half a sentence before the bitch promptly told me I was calling the wrong thing and put me to another press a button option bullsh*t. Wait another frikkin 10 minutes and the same thing, only this time the kind lady put me in the right queue!
When I got through, I got the info I needed and was mildly happy. I took me 30 minutes on the phone to find out that I need to present ID and my cars rego papers to have their number plates swapped...oh and the $50 revenue, oh I mean processing fee.
Today. I went to the RTA at Macquarie Centre during my lunch break. I wait about 25 minutes to be served (3 people attending and about 3 people standing around doing nothing). When I get there and present my rego papers the frikkin bitch told me that I need to present my frikkin plates! what. the. fruck?! She then pulled out the "we're sorry" bullsh*t... Seriously I'm so fed up with the RTA. Firstly they charge us a mortgage to get our cars registered and they can't even provide adequate amounts of staff and service...
NOT HAPPY JAN.
https://www.sau.com.au/forums/topic/34104-a-big-f-you-rta/
Ignorant ex-pat inquiry #477:
Whats "Not Happy Jan"? :)
Ha ha ha ha ha ha ha ha - It's a commercial over here Rezz. This woman get's pissed off and says " Not Happy Jan " casue Jan is the one she is not happy with. Anyway, you need to see the commercial to understand - It's funny as....
Hence everyone now says "Not happy Jan" -
https://www.sau.com.au/forums/topic/34104-a-big-f-you-rta/#findComment-683849
Never go to the RTA during your lunch break unless u r going to clear a canary :)
Its always packed as mofo
true but I took my lunch at 2-3PM cos most people are back at work by 2...
Useless bunch they are...seriously with the amount of money they make surely Sydney should have some of the best roads in Australia...
https://www.sau.com.au/forums/topic/34104-a-big-f-you-rta/#findComment-683852
CK: Are you getting the plates under the new $400/yr BS?
Maybe the $100 coloured plates?
The RTA is a pain in the bumhole.
I call in work time (may as well).
Tell me colleagues I may be gone for a while and pack a lunch.
You have to be prepared.
The more you know their procedure, the more you can present the right documents when they need it.
They are process workers like any other bureacracy and you're just a number (literally) so take it easy on the counter staff.
I would imagine it's the same in every country because you keep hearing about the DMV ("Patty and Selma") and the MoT on TV shows.
One day though... when the revolution happens, they'll be first up against the wall.
T.
https://www.sau.com.au/forums/topic/34104-a-big-f-you-rta/#findComment-684017
Personally I feel sorry for the RTA counter workers.. they have to deal with every f*cking lunatic on the road -- half of whom are brain dead -- so take pitty and be as nice as you can (stomach), because its often far more productive than being agro.
LW.
https://www.sau.com.au/forums/topic/34104-a-big-f-you-rta/#findComment-684020
nah 400 a year is the leet plates, rego is about 800 including ctp insurance.
I had to go on Saturday to renew my rego last dec, waited for 1.5 bloody hours :)
But, for a bit of fun, next time you are there, get a copy of your driving record, it costs about $20 and mine looks a bit like a novel :spank:
https://www.sau.com.au/forums/topic/34104-a-big-f-you-rta/#findComment-684258
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
