Dude, that's sick! doubles as a strut brace by the looks of it! I wonder if it lacks strength because it has hollow cavities for oil cooling?
Imagine taking a tight corner, putting stress on the strut towers and then it cracks, pissing oil all over the top of your engine hahah
yeah it's just an oil/water heat exchanger. to make the most of it you'd need a larger than standard radiator or a second smaller radiator to cool the coolant flowing through it. they just chose to make it look fancy and mount it on the strut brace. no way would you buy it for $1000.
for similar money PWR will make you a GTR radiator which is twin pass and has an oil cooler/heat exchanger built into it. used on may serious track cars. very effective in that they also help bring oil up to temp and then keep it stabilised at operating temp. so then you're getting a better radiator AND the oil cooler for the same money.
Spot on!! :P
forgot to mention that it looks to me to be a laminova type core. they make special cores for turbo engine pipework and also make sealed oil/water heat exchangers/stabilisers. very interesting type of core and apparently quite efficient.
What diameter pipes do they use? I had thought of getting a filter relocating kit and running it through the heat exchanger in my auto radiator (have converted to manual). Then if I need a bigger radiator at that point I could add a proper oil cooler and thermostat.
Anyone have the yahoo link?
http://page21.auctions.yahoo.co.jp/jp/auction/j94861066
i found it again, looks like it didn't sell at the price of 89,000yen so the started the auction again at a starting price of 1yen with no reserve.
pretty cheap atm, about the same cost as a strut brace might bid of it for some giggles
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
