Best Place To Buy Black Silicone Joiners In Melbourne
Hi All,
As the topic suggests I am trying to find the best place to buy some black silicone joiners to replace my factory rubber. Is there a shop in melbourne that people know of that is a good price and good quality? I hate the monza brand that autobarn have plus they dont have black.
I was hoping to find a physical store instead of an online store if possible, unless someone has a really good online store to recommend?
i know of this place near repco in oakleigh...not sure you already know about them...seen a lot of blue silicon hoses but you can ask them if they have black...give me a bit and ill try to find the name of the place...
VPW
122-128 Cooper St
Epping VIC 3076
(03) 8405 9200
cheap and awesome.
EDIT: http://www.vpw.com.au/category.asp?CatID=7...mp;SubCatID=985
Wow those prices are fantastic! Thanks heaps!
$35 for a bend in 3"? ouch.
$150 won't last long lol.
just look on ebay, same shit stuff, just cheaper.
be interesting to hear if the VPW stuff is reasonable quality or not.
2.5 inch last time I checked :P $28.43 for a 90 degree bend
Theres only 2 of them, but yeah it is still going to add up.
Spareco
8 Park Road,
Oakleigh, Victoria,
3166
They have some cheap stuff and good quality ones. They got lucky dip tubs where me and my mate bought less than $5 stuff that worked great. Never complined about the hoses bought from there so will recomend it.
Purple Pig. Can't remember if they're in Ringwood or Bayswater, but around that area. Sell heaps of silicon joiners and been recommended to go there by a few people in the auto trade for stuff like that now.
any truck parts shop would have them
Ok i tried this and they actually have blue and black hose but its not glossy its a matt colour, very stealth in black..Which is cool..And pretty cheap
On the corner of stud and canterbury rds mate next to TTF kinda...They have other stores around too..
  • 1 month later...
http://www.vpw.com.au/category.asp?CatID=788&SubCatID=985&priorCatID=788
another thumbs up for the VPW stuff.
been using it for years now and never had a single failure.
have had ebay crap and other brands that has failed on customers cars when they have supplied it. replaced with proflow silicone hose and never had a single issue again.
yep go for truck part shops, they will never break and last a billion kms given the reliablity requirements they have
also should be cheaper and not mega shiny
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
