Heya all.
Recently noticed some rust on the floorpan of one of my cars and just looking for a good place to take it to that won't charge me my unborn and a kidney..
Any suggestions sydney skyliners?
If you can post up roughly the amount of work done and cost that would be really beneficial.
Cheers!
https://www.sau.com.au/forums/topic/342068-floorpan-rust-repair-in-sydney/
sorry can't recommend anyone ... I've had some strut tower rust taken out by a mob in seven hills but they did such a bang up job I need to go back in less than a year as it appears worse now.
I've also got a lot of surface rust on the floor pan (from below the car/outside) and intend to get an airblast thingo attach it to my dad's compressor and sand blast the crap out of it, then fishoil the whole underside (literally drench it in fishoil).
If anyone can chime in with a really good rust repairer that'd be great .. I've already gotten 2nd hand strut towers so that mine can get repaired but don't trust the mob who did the original job, one bit.....
Buy some axle stands and an angle grinder with a big wire wheel, and be prepared to get dirty.
Will be the cheapest way, if they havent rusted right through then treat the whole underside with a rust preventor/inhibitor then spray the thing with underbody sealer.
Just make sure you get every little nook and cranny cleaned out.
Might take you a few weekends but will save you giving up your 1st born.
speaking of stands ... what's the safest method if I'm going to be under the car whole weekend screwing around with sandblaster ? Bear in mind I don't even have a jack now.. Would ramps be better/safer/cheaper than axle stands? Where can I get a decent jack (can I rent one?)
Yeah you can rent one from Kennards/coates etc. or Autobarn/super cheap/repco sell ok jacks reasonably cheap, but get a 2-ton one, atm i have a cheap 1400kg one and it sucks!
ramps are better than stands imo, but depends on whether you need to get wheels off etc.
My trick is if you have some old steel wheels lying around, jack the car up and stick the old shit rims under your wheels/tyres and the front and rear.
It seems to be rusted through at this one spot only (i presume from a water leak at one point) so will definitely need to goto a shop. I do know a shop that can do it however their work has dropped a bit in quality over the last several years unfortunately which is a shame as it used to be top notch.. however i might use them anyways seeing as i won't even be able to see the repair at all considering it's to the floorpan and there shouldn't be any paint etc involved..i'd just get it galved afterwards.
Ramps would be good wackydee. If it was me, i'd use a trolleyjack to raise it then also put jackstands underneath for if the trolleyjack fails. Like said, you can get ok jackstands from autobarn etc. There were some recent recall on repco ratchet stands so keep that in mind (failed and crushed someone to death from what i read on here).
Anyone else that's had this done?
for all things panels i would definitely stop in to talk to Louie at Xclusive Colours on the Cumberland HWY in Smithfield, he is the most recommended panel beater on this forum and is very fussy about his work.
here is another sau thread recommending him
http://www.skylinesaustralia.com/forums/pr...=21&t=79041
here are his details
http://www.yellowpages.com.au/nsw/smithfie...54-listing.html
alot of people have also had good results at Smashtech at Bankstown
feedback
http://www.ozhonda.com/forum/showthread.ph...astle-or-Sydney
details
http://www.smashtech.com.au/index.html
hope that helps
danny
Edited by squareznboxez
I used to work at a custom car and restoration specialist in Fairy Meadow called Classic Fabrications. Awesome quality of work and as they only do resto's and custom work they are very used to rust repairs. Dont charge excessive amounts either.
Can give u details. If its only a small patch of rust, rip the carpets out and take it down - reckon it'd be only a day or two to fix.
I use & definatley recommend Exclusive Customs http://exclusivecustoms.com.au.
If you want the job done properly & they are located at Kingsgrove. Give them a call & ask for Jason 9502-1496 & tell him Batman told you to call.
small patch of rust = day or 2 ??? What's that 10 hours labour at $80+ ?
I didnt mean a day or two of time to repair - I meant a day or two to complete if you want the underseal to be nice and dry (once repainted) before he drives off. I think most workshops would have a car for at least a day when doing a rust repair - drop off in the morning & pick up late afternoon/next day - dont you?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
