So my engine finally let go last night!
I have a motor to pick up tommorow to fit, but while the engine is out of the car I thought to myself why not pick up a few goodies and power her up a bit!
After doing some research on here and looking at other's setups, this is what I'm thinking of doing.
I already have an exhaust/fmic and AVC-R.
Hypergear ATR43 G2 profile
Z32
Fuel pump
S15 injectors
Nistune
New clutch while engine is out/lightened flywheel
I'd like just a nice responsive street setup. I think this is the way to go.
Any feedback?
Cheers.
https://www.sau.com.au/forums/topic/342526-build-time/
yeah, i was thinking with those mod's id get a nice setup for street. I don't want a dyno queen, just a reliable daily with some nice power to boot.
I'm after torque more than anything, at the end of the day kw mean shit to me, it's how much better it will drive.
https://www.sau.com.au/forums/topic/342526-build-time/#findComment-5525004
if you dont care about kw's but want it better to drive just stick to the standard turbo and spend the money on handling, new bushes throughout, a good brake setup and good new tyres...
it will drive great...
https://www.sau.com.au/forums/topic/342526-build-time/#findComment-5525017
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
