as if you can talk lol
I haven't blown up things because I fiddled though! I blame my right hand foot for being so heavy when the motor blew! :P
1 motor blown in 25 years of driving, racing ect.....
Whats you number in 4 years????
previous tuner wasnt the builder.
according to sabbadin, the build is amazing. had the head off and went over everything. tuner on the other hand.. havent really heard anything good. so yeh wanted to get it retune anyway.. just didnt want it all to happen at once.
edit
built by http://www.engineaction.com/
it's amazing how much you can spend when you have an unlimited cartel budget! :P....even from where that car started its rebirth!
1 motor, my first one. i havnt blow up any other engines..
supra with nos, and that was down to my left hand holding the button lol...
i didnt short this terminal either.. what are you getting at..
seem that this is the only blowing your getting :nyaanyaa:
rebirth?
nope was built as a show car..
aaron - 1
Craig - 0
BAHHHHH!!!!.....you call that 1???
Oh your talking since you purchased the Jaffa!....thats OK then.....pretty pitiful effort though....but you can have it.
So M35 days
Craig 342397583957834151345681347579834753485643875
Aaron 0
Jaffa days
Craig 0
Aaron 1(but a pitiful 1)
:P.......lol!
So M35 days
Aaron 0
Jaffa days
Craig 0
:P.......lol!
atleast I personally didnt blow up an M35.
strange that the two to blow up are both Black ARX's.
So, i recieved a ticket in Coffs Harbour for performing an illegal U-Turn.
The officer didnt fill out the ticket correctly.
Should I dispute this?
Perhaps the wrong question; what can I do to dispute this? Do I need to take it to court? Or will a letter suffice?
Its not a spelling mistake, he has incorrectly filled out some essential fields to do with the date and the fine code. IMO, making the ticket null and void as these are fairly important.
hmm i got a speeding fine last year, but that was the first one in around 5 years
if i write a letter, they may correct the fine and send me another one with correct information.
If the officer handed you the ticket; it doesn't matter what it has written on it, if you dispute it; they'll just re-write it.
If it arrived in the mail with an incorrect rego, road name or date; dispute it, you weren't there/not your car. Of course if they have video; you're still likely to be f**ked.
If you did the wrong thing, and know you did the wrong thing; cop it on the chin.
lol i knew someone would say that
however, im not saying im being unfairly punished. i just dont want to pay if i dont have to.
if i dont do MY job properly, i dont get paid
lol so you never get paid properly then?
thanks dude. im a little worried about it, but it should be good!
Iain.....don't forget to suck down some protein shakes for the Gearbox change overs tomorrow!
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
