Hi all,
A few of you will be aware I have been troubleshooting a loss in power and an increase in lag. I used my custom made boost leak to identify a boost leak at the outlet of my trust return flow intercooler.
I tried replacing the hose and clamps and still keeps leaking.
I pulled it all apart and the intercooler has a crack in the outlet end tank and a chip missing from where it connects to the piping.
Can this be repaired? Is there anywhere in Melbourne people would recommend to fix this?
Any help much appreciated!
I know some one who can weld it for cheap. SMSed to your phone
Its looks like an end less leak hunt with new leaks discovered every couple of days. I think even the 279rwkws you've made was with leaks every where.
Hi all,
bugger thats been repaired once too... any radiator shop could fix it or drop it past tao.
Yeah it is been repaired at least once before! I am a little worried that it may do this again.
What other options do I have? Could I get a new end tank welded on?
What other return flow intercoolers are there on the market? I am just worried that if the inlet and outlets are in different locations I will also have to modify the piping!
GRRRR! This is the only second hand item I have purchased for my build and its hurting me already.
If you get someone thats really good at welding it up it shouldnt break, it all depends on how good the welder is.
+1
if only you saw how many welds are holding mine together :)
Edited by Arthur T3
Ok that's good to hear, thanks fellers!
Trent its a trust return flow intercooler which I can't seem to find anywhere. If it was a jjr one I would just buy another one. The piping had to be modified to fit so I would have to get the piping modified again.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
