Hi All,
i have just completed my rebuild of my RB26 engine, spec are below
the tuner told me that i can't higher the boost due to the injector has already max at 85% or more. if we would to push 1.5 to 1.6 bar the air fuel will lean down. i have attached the dyno sheet.
The question is that i see some of the forumer here have smaller or similar size of injector but could push a much higher WHP.
Is there any problem with my setting or tuning?
RaceTech 86.5 mm piston
TOMEI 1.5mm @ 87mm metal head gasket with oil restrictor
Jun Oil Pump
Balance crank, piston, rod, clutch, main pulley
Refresh Standard Head
HKS step 1 IN/EX 264 cam
Jun Cam gear
BC valve spring
Greddy type 6 throttle intake manifold
SARD 720cc injector
HKS type fuel rail
Tomei Fuel regulator
Garrett GT35R AR1.06 split type
aftermarket ex manifold split type
Tial 44mm ex wastegate
Power FC D Jetro
ETC ETC...
Thank you in advance
DC
https://www.sau.com.au/forums/topic/343175-rb26-720cc-injector-max-out/
Would have thought 720cc capable of quite a bit more power. Pressure on idle is fine but Walbros flow chart shows flow drops off sharply when pressure goes up so I imagine having two of them won't change that. I guess adding an external Bosch 044 or two with a surge tank would solve the problem.-
lol idiot!
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
