  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Cy, Haha, funny how you don't mind saying that Ben sucks you dick, but get upset about smearing him in chocolate:p
It wasnt the chocolate stuff, it was what i was going to type after it, but it was just too sick, I just couldnt type it, I was having trouble not dry retching even thinking bout it, YUCK!
Come on Thursday, Get Ben's Mum to drive you!
She drives a RAV4, wouldnt be able to keep up!
home time yaay, wonder if it'll still be raining tomorrow, well at least I am finished working outside, the optic splicers are coming tomorrow morning and they can deal with it, be nice to go back to fibre speeds, hmmmmmm 1000 Base-T :drool:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
