  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
OI Ben Please dont install or change anything, I had to try to explain to my boss how come i had to spend 3 hours formating that new PC to take home to replace the other one.
I'm not blaming you, just a warning that's all :) if it happens again = no ADSL at home for anyone, inc me :D
Wait... You're saying that if chaos ****s another computer, you get kicked off the net forever? As well as him?
Go ben go! I will give you lots of links for stuff to install! LOTS OF STUFF! HEAPS OF IT! MANY MANY PROGRAMS GUARANTEED TO FUX0R YOUR BOX!
*gigglecopter*
:) I'll still have the net here at work, that wont change, my boss was just not happy that I had to waste 3 hours of the companies time fixing a company computer I had at home.
Because I have a lappie now, it was hard pressed to get another crappa pc to take home.
That computer has been running fine for ages until someone started installing crap on it, and I know it was not me. That leaves only 3 other people who use it. I know who it was, she is just too stupid for words, really!
yup i noticed it on wednesday when i got home. Something just above the task bar.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
