  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
:wavey: whats been doing erin
did andrew have any luck finding the problem with the car???
Not sure. I guess he'll look tonight. He went straight to bed when he dropped me off last night. I think it just badly needs to be tuned. Like *badly*.
But someone said it's a common trait of the Haltech computer to drop and pick up revs like that. *shrugs*
yeah also thats what a failing TPS switch dose makes it hunt in the reves
is yours dropping n picking up revs Erin? Mines stalled lately and then the enxt moment its idling at 2000rpm ..... weird stuff. But its not regular enough to go to a mechanic - this is whats wrong fix it.
Mine was doing that BEFORE the PowerFC and it was a blocked throttle body. You can try and clean it out? Or get one of the guys too. It was quite embarassing pulling up to an intersection adn the car dieing on me.. Then it would rev at like 2000rpm. Embarassing!
Mike was talking about Andrew's car. He's bought a VL Turbo and it was having quite a few issues last night. He thinks he's worked it out to be the alternator. Or buggered battery.
Why do we always have to have issues with cars and their alternators :(
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
