  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
dOING WORk at the moment (typing in caps sorry)
I'll just have it so I can challenge the maintenance manager when he's trying to beat his wifes score :)
They've all got XP and I've got Win98. Sucks to be me!
lol well like I said I will swap ya u can come take my place here being sick & I will go to work sounds fair to me :(
hahahaha challenge the maintenance manager sure sure :D
how come ur the only one with 98??? thats not fair :(
cAUSE THIS place sucks?
My computer sitll works so theres no point replacing it. Apparently. Even though I have a hell of a time with programmes and databases because I've got a crappy old programme that doesn't support most of the functions of xp. But it doens't matter. My computer's not broken!
Yes I am bitter and twisted.
How can I break my computer?
My typing also sucks.. obviously. Look at the errors in that last post!
hahahahaha I think it may be because ur wanting to be some were else right erin :)
if ya want to kill the computer I still got a virus on the computer that simtext has found & awaiting me to get ride of it I could always send it your way its one of thoes horsey ones lol :jk:
BOO!
so whats every one been upto this week ????
work, drifting at movieworld work
Woohoo! Andrew just helped me install games on my comptuer. They hadn't installed them. But I found the win98 cd and got andrew to show me how to install them :)
It's users like you that made me the bitter nazi-like twisted hard ass network admin i am today :D NO ONE on my network can install anything, but me mUAuauaU uA UAUhAha hH AH AH AH h H AHAH H AH AH h Ah AH aH !!
I have had to replace several PC's here that have had a cup of coffee "accidentally" knocked over onto :(
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
