  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hail? there will be no hail.. wrong conditions..
Negative... Here's some pics from my house at 3.15pm this afternoon. :crazy:
The Back Yard...
Outside the garage door...
The Front Lawn...
The M1 complete with stopped cars, hail and police...
A "big" hail stone...
A cryogenically modified to be "orange size" hail stone ...
The car was safe and sound though... just...:sly:
We only got hail the size of a pea last night.. Nothing today thank god. But I still came home and covered sinbad up in his quilts and car cover.
I did hear on the radio reports (net was down) that there were hail stones the size of golf balls falling at yatala smashing windscreens all over the place.
Negative... Here's some pics from my house at 3.15pm this afternoon.  The Back Yard...
I don't believe you.. those photos are staged - you made them up!
Didn't get anything down on the goldcoast at all that looked like hail :confused:
weird ass north goldcoast!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
