I heard he was in jail on drug charges.  Must have been his missus.
I don't think so as I was having a pizza with him on Thurs night...........unless he's done a runner LOL
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
59ANK went past me this morning on the ICB, nice looking car...you are a daring individual for driving that way along that bit of road...
Oh and a maroon series 1 followed me past the Roma Street Courts this morning afterwards...bloody sjylines are everywhere!!!
So that WAS you! I saw the Workshop sticker on the back and figured as much.
I'm on that bit of road at least twice a day monday to friday...
Yes the old line does not get out much, seems too many Commonwhore and Falcodicks driving around who want to race you at the lights...
I need a bucket to drive me thinks...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
